headers???
Old Jan 28, 2005 | 11:16 PM
Karterguy13's Avatar
Default headers???
will a GSR header fit an LS?
Old Jan 29, 2005 | 12:01 AM
ben_eg6's Avatar
Default Re: headers??? (Karterguy13)
it might be a lil shorter than the ls cuz the gsr cat is very long. obd1 ls header has an o2 hole but the gsr doesn't .
Old Jan 29, 2005 | 08:13 AM
BlackSage's Avatar
I believe the 00-01 gsr header is a direct fit
Old Jan 29, 2005 | 09:02 AM
purplegsr's Avatar
Default Re: headers??? (BlackSage)
Depends on the year, a 94-99 GSR header will have no o2 bung, while the 00-01 does. Like Blacksage said, the 00-01 GSR should be about the same length, because the cat and exhaust are similar between the 2 models. If you have a 94-99 GSR header and a 94-95 LS cat, you will have no o2 bung at all, and you would some customizations to make the exhaust, header and cat fit together, and add a bung.
Old Jan 29, 2005 | 12:59 PM
Default Re: headers??? (purplegsr (Exospeed))
so it will bolt up to the head?
Old Jan 29, 2005 | 01:05 PM
BlackSage's Avatar
I am almost positive that ALL b series header will bolt up to the head w/o problems. The bottom part (I think it is called the A pipe) has all the problems
Old Jan 29, 2005 | 01:31 PM
I thought so but wanted to make sure. THANK YOU GUYS!!!!!!
lsvtec101
Mar 16, 2009 08:44 AM
80 dolla crx hf
Oct 3, 2008 04:28 PM
kwu808
Nov 18, 2006 05:28 PM
eg64u
Aug 1, 2004 02:44 PM
MugenGTR
Aug 18, 2002 03:16 PM
