LS Build Questions ? ? ?
Old May 24, 2004 | 07:07 PM
Dent Free's Avatar
Default LS Build Questions ? ? ?
Hey guys.
I am getting a 93-94 Ls Block and trans for my 88 hatch for pretty cheap and the goal is to keep it low buget.
I have SiR II pistons I got for free with the bearings.
My question is I plan to put those in and honing the block and getting some cams ( street/strip -- But with good Hp numbers).
What else should I get to keep it safe for a 50 shot every once and a while and what cams do you all think is best.
Also keep in mind that all work is being done by me ( I am a mech for Volvo - 3 years exp. )
All posts would Help --- Thanks
Old May 24, 2004 | 08:05 PM
Dent Free's Avatar
Alright guys I have looked around and found a couple of people with cams ( 403 , 404's ) and they say they are the **** when tuned but not one person has them with P30 - SiR II pistons.
I also know that I can get a B16 cable trans for $400 So I am But . .
Anyone have any help.
Old May 24, 2004 | 09:27 PM
shermanyang's Avatar
Default Re: (Dent Free)
you better get 81.5mm pistons cause i'm sure that's a pretty old block and you're gonna have to bore it out .5mm to make oem pistons fit sungly in.
Old May 24, 2004 | 09:34 PM
Dent Free's Avatar
Default Re: (shermanyang)
Thats a problem cause I already have the pistons --- I got them for free.
The block only has 90K on it so I don't think it should be that bad --- Nothing a good honing shouldn't fix.
I had a Volvo with 285K on it and I honed the block and replaced the cracked piston and it held compression with all the other 3 cyls. So I think it should be ok. May people have done it.
Old May 25, 2004 | 01:24 PM
Dent Free's Avatar
Anyone have any results with Si pistons with 403, 404, 405 cams?
Anyone ? ? ? ? ? ? ? ? ?
Old May 26, 2004 | 09:23 AM
No's Avatar
No
results with si pistons and 404's around 170 or so.Depends on too many other things,look from 160-185
uscivicmc
Mar 4, 2012 07:13 PM
lluks_844
Northeast (Sales)
Sep 17, 2009 10:15 AM
krazyturbo1
Jan 8, 2008 05:28 PM
ls_bitik
May 27, 2007 11:56 AM
yellaboi
Nov 18, 2003 07:51 AM
