ls bogging down
Old Feb 2, 2009 | 09:28 PM
94-integra-ls's Avatar
Default ls bogging down
ok so heres a run down on the car. Its a ej civic with a obd1 ls swap when i got the car it ran just fine. I put a turbo kit on it and it ran fine for a while when i took the kit off it started acting really wierd. The car started bogging down really bad where you can barley get the car moving without it dieing. I have replaced the injectors the map sensor dizzy 02 sensors and the ecu i also put another tps sensor on but im not sure if it was good it was used. i know the iacv is bad its throwing a cel but it should only cause the idle surge problem i have not the bogging issue. any help would be greatly appriciated.
Old Feb 3, 2009 | 09:01 AM
mouab18c1's Avatar
Default Re: ls bogging down
actually the IACV can affect on how your performs...so i say replace it....and did you calibrate the TPS?
Old Feb 3, 2009 | 09:16 AM
j_bizach's Avatar
Check ur fuel presure and fuel filter
B18B_EJ1
Dec 28, 2012 09:13 AM
Blazen_angles
Sep 10, 2012 01:12 PM
LilCivic04
Jul 31, 2005 09:38 AM
JDMworld
Jun 14, 2005 03:41 PM
Boriqua0555
Jun 7, 2004 10:45 AM
