lowing coilovers for 94 integra ls
Re: lowing coilovers for 94 integra ls (jaysterrr)
1. Search, this has been asked plenty of times. Don't forget to include archived content when searching.
2. We need more information. Its really hard to help find whats best for you when you give us nothing to work with.
Budget
Use (Auto-X, Roadrace, Drag, Daily)
How much of a drop do you want?
Ali
Budget
Ali
Re: lowing coilovers for 94 integra ls (BlueIntegraBoy)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy »</TD></TR><TR><TD CLASS="quote">Street... many people will suggest Ground Control with Konis</TD></TR></TABLE>
This is also a great track setup as well.
Ali
Ali
Re: (jaysterrr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jaysterrr »</TD></TR><TR><TD CLASS="quote">sorry i didnt leave much info i ned lowering coil overs that are really stiff and does not bounce</TD></TR></TABLE>
What kind of budget? What are you going to be using your car for (Roadrace, Auto-X, Drag, Daily)?
Koni's and Ground Control Coilovers are known to be a great setup. The koni's can handle around a 400-500 pound spring rate without needing to be revalved. Also the GCC let you order any springrate you want without an additional charge. But the off the shelf rates paired with the koni's are a great setup and is pretty stiff if you set it to a stiffer dampening.
But there are also other great setups but like i said before we need to know your budget and intended use.
Ali
Ali
