Low Compression, low vacuum?
Old Aug 21, 2003 | 05:30 AM
SupaTeg's Avatar
Default Low Compression, low vacuum?
Does lowering you compression affect vacuum in anyway?
Old Nov 27, 2005 | 06:36 AM
pK1spooled's Avatar
Default Re: Low Compression, low vacuum? (SupaTeg)
anyone?
Old Nov 27, 2005 | 01:32 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: Low Compression, low vacuum? (pK1spooled)
Yes, of course it does. But by a negligible amount. Any change in combustion characteristics (whether it's from compression changes, spark delivery, fuel delivery, etc) will have an effect on vacuum pull. However, the amount that it will change will hardly be noticible, even on a normal vacuum gauge/boost gauge.
It definitely won't have an effect on any sensors, BOV, etc that you will have attached to vacuum.
Old Nov 28, 2005 | 02:58 PM
ohsnapzafingcu's Avatar
I serve phở for my babies
Default Re: Low Compression, low vacuum? (shamoo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by shamoo &raquo;</TD></TR><TR><TD CLASS="quote">Yes, of course it does. But by a negligible amount. Any change in combustion characteristics (whether it's from compression changes, spark delivery, fuel delivery, etc) will have an effect on vacuum pull. However, the amount that it will change will hardly be noticible, even on a normal vacuum gauge/boost gauge.
It definitely won't have an effect on any sensors, BOV, etc that you will have attached to vacuum.</TD></TR></TABLE>
nice
Old Nov 28, 2005 | 03:16 PM
Default Re: Low Compression, low vacuum? (ohsnapzafingcu)
ohh sheit.. wasssup teeeejayy!
Old Nov 28, 2005 | 03:34 PM
3.504's Avatar
super correct
remember vacuum is more related to the overall health of your engine. changing static compression would theoretically have an effect, but you have to remember... you had to take apart the motor and reassemble it to change the static compression. when you reassembled it you sealed it better and now you're making better vacuum regardless of if you dropped or raised compression.
now cam selection will have a major effect on vacuum.
P@@RB@Y
Nov 16, 2005 12:39 PM
cornhusker
Sep 20, 2003 11:36 PM
Nameless RB26
Apr 10, 2003 01:53 PM
schwett
Sep 6, 2001 08:31 PM
