Quick Q: Fixed Compression Gauge...
I had a compression done on another B16A and the numbers came out 240 accross.The engine was cranked over more than 7 times.Would this give you higher numbers than normal?
Also theres no way to rig a compression guage to give you the number you want is there?
Thanks
Thanks
Guest
Posts: n/a
Re: Quick Q: Fixed Compression Gauge... (P@@RB@Y)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by P@@RB@Y »</TD></TR><TR><TD CLASS="quote">
Thanks</TD></TR></TABLE>
wth??!
you plan on scamming someone?
wth??!
Re: Quick Q: Fixed Compression Gauge... (mike93eh)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mike93eh »</TD></TR><TR><TD CLASS="quote">
wth??!
you plan on scamming someone? </TD></TR></TABLE>
NO Its a car Im buying.Just wanted make sure theres no way a gauge could be rigged to give numbers you wanted.Stop being so Su******s!
Thanks though
wth??!
Thanks though
bring your own guage if youre worried. Once it reaches the max compression it wont go up any more, so no cranking it over 7 times wont give you higher #'s, you might even have to crank it more than that... Im sure a comp. guage can be rigged, but that would be too much of a pita and you would have to be pretty smart.
Re: Quick Q: Fixed Compression Gauge... (TurboCoop)
I looked at the gauge and it was all the way down.Then every cyc. went to 239-240.Last time it read 215 across.
DjFreeze
05-15-2004 06:47 AM
