compression reading w/ oil added
Old Jun 4, 2009 | 11:13 AM
eg:R's Avatar
Icon5 compression reading w/ oil added
when doing compression readings w/oil. how much psi of a jump will consider bad rings?
Old Jun 4, 2009 | 01:30 PM
delsolproblems's Avatar
Default Re: compression reading w/ oil added
Usually you want the no-oil reading to be no less than 80% of the oil reading. This percentage increases somewhat with valve leakage.
Old Jun 4, 2009 | 08:10 PM
Jdmsoles's Avatar
From: Dodgin Cops all Round Ana-Crime to Orange & Sd
the way i see it if your below what your suppose to get w/out oil and with oil it is at normal cylinder pressure then you know your rings are bad, not necessarily knowing the percentage just judgment of knowing. If that's any help
jonyi27
Apr 21, 2014 11:55 AM
blackeg
Jun 26, 2011 08:53 AM
Jeff
Apr 18, 2005 06:23 AM
Layziebtnh055
Jun 22, 2004 03:25 PM
