Loose Steering!! Help
Old Jun 6, 2002 | 10:43 AM
95BlackGS-R's Avatar
New User
Default Loose Steering!! Help
what can cause your steering wheel to feel loose while driving along. when at a dead stop the steering feels normal and somewhat stiff. there is no loss of steering response whatsoever just the steering wheel feels nervous at high speeds.
besides tire pressure what else can this be?
Old Jun 6, 2002 | 10:55 AM
96IntegraLS4DR's Avatar
Default Re: Loose Steering!! Help (95BlackGS-R)
Toe might cause this problem.
Old Jun 6, 2002 | 11:07 AM
New User
Default Re: Loose Steering!! Help (96IntegraLS4DR)
is toe part of an alignment issue?
[Modified by 95BlackGS-R, 12:08 PM 6/6/2002]
Old Jun 6, 2002 | 11:20 AM
harryg's Avatar
yes
Old Jun 6, 2002 | 11:25 AM
New User
Default Re: Loose Steering!! Help (harrytg)
does that mean its like :
OR
Old Jun 6, 2002 | 11:39 AM
GSRaCeRbOI's Avatar
toe is whether your wheels are pointing straight forward..
if im reading your diagram correctly.. what you had is camber and caster..
Old Jun 6, 2002 | 11:41 AM
gsxr's Avatar
Default Re: Loose Steering!! Help (GSRaCeRbOI)
looks like camber straight forward...but from a top view, looks like toe settings.
i'd like to know about this too..
Old Jun 6, 2002 | 11:53 AM
GSRaCeRbOI's Avatar
Default Re: Loose Steering!! Help (gsxr)
oh yeah i was lookin at it from a straight forward point of view since he put "or" anyways...Toe-- from a viewpoint above a car, toe is the angle of a wheel indicated when the front of the wheel is pointed more inward or outward than the rear of the wheel. When the front wheel is angled more towards the center of the car than the rear of the wheel, the wheel has toe-in. When the front of the wheel is angled away from the center of the car more than the rear of the wheel, the wheel has toe-out. Toe-in increases straight line stability. Toe-out increases response to steering inputs, but can cause a car to be unstable when driven across road surface imperfections.
Old Jun 6, 2002 | 12:01 PM
red97gsr's Avatar
OR
Yes, that is toe when viewing from above looking down. If your toe is out, like the bottom pic, then your wheels want to wander a little more and your steering may feel a little loose. Or check your tire pressure also. Sometimes that can contribute to the loose feeling.
Old Jun 6, 2002 | 01:01 PM
ingrate's Avatar
25 Year Member
Default Re: Loose Steering!! Help (red97gsr)
i've found that toe-out makes the steering feel more responsive.
Domani99
Sep 5, 2012 04:29 PM
tonykdee
Honda Civic (2001 - 2005)
May 27, 2009 07:49 PM
Charri
Oct 17, 2007 11:26 AM
EG6R
Suspension & Brakes
Aug 6, 2007 01:46 PM
WangChung
36
Dec 10, 2003 07:34 AM
