Loctite
Old Feb 5, 2002 | 05:41 AM
backlash's Avatar
Default Loctite
When you guys/gals put your exhaust's on did you use loctite on the nuts and bolts? Thanks.
Old Feb 5, 2002 | 05:51 AM
b18b98's Avatar
Default Re: Loctite (backlash)
I didn't and its been fine so far.
Old Feb 5, 2002 | 07:35 AM
Phat Corolla's Avatar
New User
Default Re: Loctite (b18b98)
If you put Loctite on them, you may never get them off again. Exhaust bolts are hard enough to get off as it is. I wouldn't use it.
Old Feb 5, 2002 | 08:05 AM
GSRaCeRbOI's Avatar
nope i did not use loctite on the exhaust bolts
Old Feb 5, 2002 | 07:04 PM
Rtzx9r's Avatar
GDD 1%
Default Re: Loctite (GSRaCeRbOI)
I would use anti-seize. It prevents rust etc. Goop it up and it should make them come apart easier next time. Good auto parts stores sell it, it comes in a silver can about the size of a small drinking glass. You can also use this on wheel studs, pretty much anything that you work on and put together that is nut/bolt related.
Old Feb 6, 2002 | 12:52 AM
Biggspeed's Avatar
Default Re: Loctite (Rtzx9r)
Yup... Loctite will just give u probs. in the long run. That anti-seize is a great idea!
Old Feb 6, 2002 | 04:29 AM
Neo's Avatar
Neo
Anti-seize is your friend Good idea to use it on exhaust bolts... never thought of that one. It is a MUST for working on brakes. I never crawl under the caliper without it...
Old Feb 6, 2002 | 01:40 PM
98SILVERGSR's Avatar
From: I want a 3some with Chasey Lane and Jenna Jameson, Canada
Default Re: Loctite (Neo)
[QUOTE] Anti-seize is your friend Good idea to use it on exhaust bolts... never thought of that one. [QUOTE]
You could also use some locknuts...those don't come off very easy either
[Modified by 98SILVERGSR, 5:08 PM 2/7/2002]
teknikEG6
Oct 2, 2005 12:14 PM
White V6
Aug 3, 2005 08:19 AM
drifter_for_life06
Jun 30, 2005 06:12 AM
projectPSI
Jul 21, 2004 07:57 AM
project dc2
Mar 13, 2004 09:59 AM
