lil overheating problem
Old Jun 1, 2004 | 04:05 PM
sihatchyvtec's Avatar
Default lil overheating problem
for some reason after i put on my new skunk 2 manifold, my gsr started to over heat, i have a 92 civic si radiator cooling it, however it was working fine til after i put in the new manifold.. neway i tried bleeding the radiator lines, but still to no luck.. can some1 tell me what i should do, and run over the bleeding procedure to get air out of the lines so i know if im doing it right, my car will not overheat until i beat on it.. when i drive normal it's fine, then a lil vtec and a lot of overheating.. ? thanx
Old Jun 1, 2004 | 04:09 PM
LSTEG96's Avatar
Default Re: lil overheating problem (sihatchyvtec)
civic radiators are half as big as the integra's right??? should this even be a question?!
Old Jun 1, 2004 | 04:38 PM
1Quikgsr's Avatar
did you cheak the level of your fluid its stupid but i made the same mistake, make sure there are no bubbles in either. good luck
Old Jun 1, 2004 | 04:40 PM
1Quikgsr's Avatar
Default Re: lil overheating problem (LSTEG96)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by LSTEG96 &raquo;</TD></TR><TR><TD CLASS="quote">civic radiators are half as big as the integra's right??? should this even be a question?!</TD></TR></TABLE>
the radiator doesnt have nothing to do with it i have a cx radiator with my gsr swap and a skunk 2 manifold with bolt ons etc no overheating here
Old Jun 1, 2004 | 05:13 PM
LSTEG96's Avatar
Default Re: lil overheating problem (1Quikgsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1Quikgsr &raquo;</TD></TR><TR><TD CLASS="quote">
the radiator doesnt have nothing to do with it i have a cx radiator with my gsr swap and a skunk 2 manifold with bolt ons etc no overheating here </TD></TR></TABLE>
do u drive like a moron all the time tho?? lol
Old Jun 1, 2004 | 05:14 PM
WeaponR
Guest
Posts: n/a
civic radiators are half the size but dual core. It should cool fine.
Michael T Lelis
Jul 20, 2015 05:37 PM
str8JDMteggy
Feb 14, 2007 10:07 AM
DelSolMarine
Oct 31, 2006 03:19 PM
vi3tromanc3r
47
Oct 17, 2006 06:11 PM
revhigh89
Jan 21, 2004 02:10 PM
