Knowledge needed !!!!!!!!!!!!!!!!
Old Nov 6, 2002 | 05:43 PM
NeXTLeVeLGeN2's Avatar
Default Knowledge needed !!!!!!!!!!!!!!!!
Ok...My bearings finally came in from back order for the main...Put them in and started car....still ticking...from the top it sounds like...tickin like a mother ******...my mechanic says its the valves...I just replaced every bearing in the bottom end by the way...crank , main , rod......is it deffinitely the valves and should i drive the car ?
Old Nov 6, 2002 | 06:13 PM
tSuperbike69's Avatar
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (NeXTLeVeLGeN2)
Just adjust the valve takes about 30 min and should be done about every 30k on a stock motor
Old Nov 6, 2002 | 06:22 PM
mugenracer's Avatar
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (tSuperbike69)
did your mechanic not mention the valves before you went and spent a shed load of money on the other parts???????????
Old Nov 6, 2002 | 06:27 PM
Fuuma0083's Avatar
ticking is mostly the valves. Its common thing on Hondas. I have the same sound, just been lazy on doing the valve adjustments
Old Nov 6, 2002 | 07:44 PM
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (Fuuma0083)
He said hes NOT gonna bother adjusting to the valves because the JDM b16a2 HEAD is going on and its all going to be new anyway...but will i screw anything else up by driving it with the valves like that...
Old Nov 6, 2002 | 07:53 PM
Cheez's Avatar
wait a minute what valve r we talkin about here???
Old Nov 6, 2002 | 08:16 PM
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (Cheez)
what ?????? obviously the ones in the car now....not in the new head.......
Old Nov 6, 2002 | 08:19 PM
SIK IN DA HED's Avatar
New User
just adjust them... dont risk anymore damage or be paranoid just to save alittle bit of money. it doesnt cost that much to get it done.
Old Nov 7, 2002 | 12:16 AM
94hondaLS's Avatar
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (dlplayboy)
about how much is not that mucH?
Old Nov 7, 2002 | 12:21 AM
New User
Default Re: Knowledge needed !!!!!!!!!!!!!!!! (94hondaLS)
well... it depends. it can range from $50-$90. if you know a mechanic or a friend who knows how to adjust valves on hondas... then see if he can help you out.
Vtec04
Engine Machining & Assembly
Nov 10, 2017 02:23 PM
02_Si_FTW
Jul 8, 2008 08:06 PM
BuyImports2
Mar 2, 2006 11:32 AM
VTECcnIT
Nov 9, 2005 05:43 AM
turbo sol
Dec 17, 2004 01:28 PM
