Just checked codes. 8 and 9
Old Apr 25, 2006 | 07:23 AM
onnoff7's Avatar
Default top dead center sensor and cylinder sensor
i have 97 ls. i just checked the codes on it. when i turned on the ignition. it flashes 8 times then a pause and then 9 times. so i believe that would be code 8 and 9. 8\code 8 is tdc top dead center sensor, and 9 is cyp cylinder sensor. How do i go about correcting this problem. could it be loose or somthing . where is it located.
Old Apr 25, 2006 | 08:19 AM
DC2 Mang's Avatar
Default Re: top dead center sensor and cylinder sensor (onnoff7)
these sensors are located in the distributor
they are usually not fixable
best bet is to purchase a new dizzy
Old Apr 25, 2006 | 04:57 PM
onnoff7's Avatar
my exact codes are p1361. tdc sensor INTERMITTENT INTERRUPTION and p1381 CYP sensor INTERMITTENT INTERRUPTION, is it possible that there could be some buildup or watever on the sensors. would it be ok to take apart my dizzy and check on that.
Old Apr 25, 2006 | 05:32 PM
DC2 Mang's Avatar
Default Re: (onnoff7)
you could take it apart to check
if there is orange dust inside the sensors are probably broken
Old Apr 25, 2006 | 06:47 PM
gsr dood's Avatar
Default Re: (JDMdc2lsVtec)
just get a new dizzy....its prob shot.....those are the only 2 sensors in the dizzy. or check the plug at the dizzy for a good connection
Milby90ls
Sep 10, 2011 09:13 AM
Unphzd
Dec 13, 2010 11:30 PM
mightymaxgst
Aug 11, 2006 08:40 PM
quik89
Nov 30, 2003 06:43 PM
Eluzion
Jun 20, 2003 12:08 PM
