OBD 1 ERROR CODES
Old Aug 11, 2006 | 04:51 PM
mightymaxgst's Avatar
Default OBD 1 ERROR CODES
I checked my engine codes for my civic and my cel flashed 8 times... what is this?
Old Aug 11, 2006 | 08:40 PM
BuddhaSiR's Avatar
Default Re: OBD 1 ERROR CODES (mightymaxgst)
Code 8. TDC sensor (Top Dead Center).
That sensor is inside your distributor. you more than likely need a new dizzy. i would first check the wiring. make sure no opens or shorts. then i would check signal from it. or you can swap in a known good one and see if you still have a problem.
nicwin
Sep 27, 2018 07:54 AM
onnoff7
Apr 25, 2006 06:47 PM
athoughts
12
Jul 3, 2005 10:16 AM
gdout90accord
Mar 30, 2005 12:59 PM
keebler65
Mar 24, 2004 10:25 AM
