jacking points
Old Jan 27, 2003 | 02:48 PM
Solipsist's Avatar
Default jacking points
Does anyone know the correct jacking points for an Integra? I'm trying to lift up the front up to work on the clutch. Is the lower core support enough to hold it?
Old Jan 27, 2003 | 02:57 PM
Regular Series's Avatar
Default Re: jacking points (TEXASLS95)
They're the little metal tabs on either side of the vehicle, on the inside of the wheel wells. There is also a jacking point on the front near the radiator (you'll see it, it's part of the frame).
Old Jan 27, 2003 | 02:59 PM
Eva01's Avatar
Under the car in the middle of the front skid plate there is a bump. This is the front jacking point. The rear jacking point is the tow hook. HTH
Old Jan 27, 2003 | 03:37 PM
Solipsist's Avatar
Default Re: jacking points (Risingson)
I assume your referring to the core support? I'm not sure if it can handle the weight of fully suspending the 2 front wheels.
Old Jan 27, 2003 | 03:46 PM
tilt's Avatar
i used the front part before but the jack slipped off of it... what do you guys do to keep it from slipping? Since then Ive been using a decent sized mdf board and jacking on the body next to the scissor jack points under the door frames but I know I shouldnt be doing it too much.
Old Jan 27, 2003 | 03:50 PM
Eva01's Avatar
Well if it's the same point I'm talking about, it hold up just fine. Jacked up my car numerous time at that point with no probs at all.
Old Jan 27, 2003 | 04:18 PM
GSRGuy17's Avatar
Default Re: jacking points (Eva01)
I've used the transmission case several times, w/ no ill effects. Not sure how hard it is on 9 yr old motor mounts (my car), but on a newer car I wouldn't expect any problems. There was no engine movement or anything.
Old Jan 27, 2003 | 04:20 PM
No, it looks like it's part of the radiator...but look more closely, you'll see that it isn't.
billybod
Jun 21, 2019 08:29 AM
sktyrhrtout
Jun 2, 2008 07:19 PM
vdub08
Jul 21, 2005 12:45 AM
nasaalien
Jun 15, 2005 07:47 AM
gamby
12
Mar 30, 2004 02:09 PM
