itr strut bar....
Old 11-20-2007, 07:36 PM
BOTAN01's Avatar
Default itr strut bar....
just wondering if anyone knows if the itr front strut bar fit up to my 95 ls? or will i have to do any other modifications?
Old 11-20-2007, 07:48 PM
Daisy... Daisy...
Dogginator's Avatar
Default Re: itr strut bar.... (BOTAN01)
It will fit. The mounting studs will not be on your LS, so you will need to add bolts.
Old 11-20-2007, 07:57 PM
SleeperGSR's Avatar
Default Re: itr strut bar.... (Dogginator)
sorry if i'm telling you stuff you know. But you might want to firm up the back before the front. It will make your car handle better. Again if you have done this or know this sorry to state the obvious. If you didn't tho something you may want to look into
Old 11-20-2007, 08:30 PM
BOTAN01's Avatar
Default Re: itr strut bar.... (SleeperGSR)
no i didnt know that. thanks for the tip. i have just been doing some research on the rear and found the asr kit that i'm thinkin about investing in what will i need to get for the mounting studs and where would i need to get it
Old 11-20-2007, 09:40 PM
RedGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SleeperGSR &raquo;</TD></TR><TR><TD CLASS="quote">sorry if i'm telling you stuff you know. But you might want to firm up the back before the front. It will make your car handle better. Again if you have done this or know this sorry to state the obvious. If you didn't tho something you may want to look into</TD></TR></TABLE>
I am not sure where you got your information from. It is always better to make sure the front is stable before the back. Of course, both front and back are supposed to be tuned together, but if he is just looking for buying a strutbar, then it is definetly better to get one for the front before getting one for the back.
Back to the main topic, if your LS doesn't have the stud already, you may want to look for Neuspeed bar instead of ITR bar.
Old 11-21-2007, 11:48 AM
BOTAN01's Avatar
Default Re: itr strut bar.... (RedGSR)
anyone know what kind of bolts i exactly need to mount the strut bar?"
Old 11-21-2007, 12:06 PM
BlueIntegraBoy's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOTAN01 &raquo;</TD></TR><TR><TD CLASS="quote">anyone know what kind of bolts i exactly need to mount the strut bar?"</TD></TR></TABLE>
Pick up bolts from any hardware store that fit just perfectly in the holes of the strut bar bracket and that is 1" long. You'll need some flat washers too.
Notice my bolts. I think I bought 1.25" or 1.5" long bolts, but obviously a little too long.
Old 11-21-2007, 01:57 PM
RedGSR's Avatar
You can buy the nut from dealer and then go to ACE to find matching bolt.
Old 11-21-2007, 02:13 PM
Naruto's Avatar
Maybe I'm just being ****, but I'd rather buy the bolts from the acura dealership if they still have them available. Something about automotive rated bolts as opposed to bolts you buy from ace hardware or home depot?
Old 11-21-2007, 02:39 PM
Jackson123's Avatar
Default Re: itr strut bar.... (Naruto)
i work at a hardware store, and worked on my stock strut today, i used high strength bolts and stainless nuts and washers. the stock are 13mm and i put 1/2" in.
Old 11-21-2007, 03:36 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Naruto &raquo;</TD></TR><TR><TD CLASS="quote">Maybe I'm just being ****, but I'd rather buy the bolts from the acura dealership if they still have them available. Something about automotive rated bolts as opposed to bolts you buy from ace hardware or home depot? </TD></TR></TABLE>
Unfortunately, you can't buy those bolts from Acura. The studs are welded to the strut tower.
Old 11-21-2007, 04:11 PM
BOTAN01's Avatar
Default Re: itr strut bar.... (BlueIntegraBoy)
thank you guys for the info much appreciated. my next question how do you install the rear itr strut bar? anyone with any pictures?
Old 11-21-2007, 04:43 PM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BOTAN01 &raquo;</TD></TR><TR><TD CLASS="quote">thank you guys for the info much appreciated. my next question how do you install the rear itr strut bar? anyone with any pictures?</TD></TR></TABLE>
If you bought yours brand new, it will cut with templates and rubber stripping for your strut covers.
https://honda-tech.com/zerothread?id=1671479
Old 11-21-2007, 04:48 PM
Naruto's Avatar
ah...well that makes sense then. ....I just looked on acuraautomotiveparts.org and all I could find was the nut
But hey...if it works....it works. I'm not gonna knock it.
Old 11-21-2007, 04:50 PM
Naruto's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BlueIntegraBoy &raquo;</TD></TR><TR><TD CLASS="quote">
https://honda-tech.com/zerothread?id=1671479</TD></TR></TABLE>
I have a spare set already cut.....it was my guinea pig and it turned out alright.....if anyone else wants it...lemme know.
Old 11-21-2007, 05:00 PM
SleeperGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by RedGSR &raquo;</TD></TR><TR><TD CLASS="quote">
Back to the main topic, if your LS doesn't have the stud already, you may want to look for Neuspeed bar instead of ITR bar.</TD></TR></TABLE>
For a fwd car you want to make it understeer less and oversteer more. Tightening the front without the back with make it understeer more, which is exactly what you don't want. Like you said it's best to do everything together, but i would have to say if i were to get one before the other to get the most performance it would be a rear sway bar. Assuming the car already has decent coilovers.
Old 11-21-2007, 11:57 PM
Naruto's Avatar
For a fwd car you want to make it understeer less and oversteer more. Tightening the front without the back with make it understeer more, which is exactly what you don't want. Like you said it's best to do everything together, but i would have to say if i were to get one before the other to get the most performance it would be a rear sway bar. Assuming the car already has decent coilovers.</TD></TR></TABLE>
Really? That's odd.....when I added the front strut tower on my car way back when, my car felt as if it had more oversteer. I of course added everything else and all was gravy
Old 11-22-2007, 12:07 AM
tomithy's Avatar
strut bars don't really have an effect on understeer and oversteer...
Old 11-22-2007, 12:48 AM
Naruto's Avatar
Default Re: (tomithy)
hmmm....that's what I figured, but adding them sure felt nice Wouldn't weight distribution ( amongst other things ) be more of a factor for that?
Old 11-22-2007, 09:09 AM
tomithy's Avatar
Sway bars play a huge role in oversteer/understeer. Just adding a larger rear sway bar changes the handling of the car completely.
Old 11-23-2007, 05:33 PM
SleeperGSR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tomithy &raquo;</TD></TR><TR><TD CLASS="quote">Sway bars play a huge role in oversteer/understeer. Just adding a larger rear sway bar changes the handling of the car completely. </TD></TR></TABLE>
My line of thinking sorry if it was hard to follow
aeros
01-21-2009 12:57 PM
Trellis
05-16-2005 06:25 PM
HATCHingMN
10-13-2003 09:44 PM
iwantfastcars
12-06-2002 01:58 PM
Platoon918
06-29-2002 08:56 PM
Quick Reply: itr strut bar....
