Intermetiant MAP and TPS CEL
Old Feb 21, 2014 | 11:20 AM
B18C-Hatch-Turbo's Avatar
Default Intermetiant MAP and TPS CEL
I have a JDM B18C stock internals with JG Edelbrock intake manifold and recently started throwing a code 3 and 7 (OBD I) which is TPS And MAP. I have checked the MAP and TPS sensors and harnesses and they are good (followed this link)
http://troubleshootmyvehicle.com/hon...e-map-sensor-3
The codes always come on together, sometimes engine starts fine and runs for a while and then they come on (doesn't correlate with engine temp) other times it will throw the code right from the start and cycling on-off removes the code and engine runs fine but doesn't seem to be a pattern.
I have changed the spark plugs and wires and haven't found any vacuum leaks. TB looks clean and IACV too. Any thoughts on what could be causing it (dirty injectors?)
any help is appreciated
regal1975
Jun 6, 2014 08:46 AM
radicaled434
Apr 28, 2012 11:34 AM
BetterBuiltek9
Jun 9, 2011 03:29 AM
hotimportcrx
Mar 31, 2008 10:28 AM
Achenar
Oct 2, 2004 01:45 PM
