interior light problems
Old May 8, 2006 | 02:10 PM
aandrewcc's Avatar
Default interior light problems
where can i find the climate control light blubs for cheap ?
Modified by aandrewcc at 9:44 PM 1/3/2007
Old May 8, 2006 | 02:11 PM
aandrewcc's Avatar
Default Re: interior light problems (drewsointoyou)
sry.. forgot to get the pics up.. but now its up
Old May 8, 2006 | 02:13 PM
Johnny Gasparini's Avatar
I didn't ask for a dime.
Those bulbs a extremely expensive to replace. The only place I know of you can get them at is the dealer. Be prepared to pay an upwards of $9.00 per bulb.
Old May 8, 2006 | 02:14 PM
.brian.'s Avatar
you have to remove the climate control. it is probably burned out. i have the same problem, i am just too lazy to fix it
http://www.team-integra.net/se...D=586
there is a link on how to remove the climate control.
Old May 8, 2006 | 07:54 PM
aandrewcc's Avatar
thanks.. i guess it is just a waste of time. and money huh ?
Old May 9, 2006 | 02:57 PM
I had one burn out on me. It was the bulb that lit up the hazard button. If you are stickler, you will pay the money like I did.
Old May 9, 2006 | 03:37 PM
VtecAdvantage's Avatar
sounds like it could be a fuse problem too.. you don't have a fuse diagram? Be 100% sure its not fuses - if thats not it, then its most likely the bulbs
Old May 9, 2006 | 05:40 PM
87shytwhip's Avatar
Default Re: interior light problems (VtecAdvantage)
double and triple check the fuses with the scamatic..the center console lights are kinda cheap..disconnect it from the dash and the floor mounts underneith and pull it off...your gonna need a screw driver and maybe a adjustable wrench.. then the climate control buttons should come right off after and the lights are right underneith..
dash lights are cheap when you have a buddy from autozone that will steal them for u..
Old Nov 11, 2006 | 12:08 PM
aandrewcc's Avatar
Default Re: interior light problems (87shytwhip)
for the lower blue circle that i circled.. which fuse is it anyway ?? thanks
Old Nov 13, 2006 | 10:07 AM
aandrewcc's Avatar
Default Re: interior light problems (aandrewcc)
anyone ?
Old Nov 13, 2006 | 10:08 AM
jdm_bones's Avatar
Go to a junkyard and get them for free 99
Old Nov 13, 2006 | 10:13 AM
Swiftstar's Avatar
Default Re: interior light problems (jdm_bones)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by jdm_bones &raquo;</TD></TR><TR><TD CLASS="quote">Go to a junkyard and get them for free 99 </TD></TR></TABLE>
ya a junkyard/Scrape yard would be a great place to check. and most likely way cheaper then going directly to a dealer.
Old Nov 13, 2006 | 11:45 AM
aandrewcc's Avatar
Default Re: interior light problems (Swiftstar)
thanks but i want to check the fuse first..
which fuse is for those light in the climate control
Old Nov 14, 2006 | 09:41 AM
aandrewcc's Avatar
Old Nov 20, 2006 | 11:29 PM
aandrewcc's Avatar
Old Jan 3, 2007 | 12:30 PM
aandrewcc's Avatar
so it is the bolt forsure
any one know where to buy those climate control bulbs ?
i cant find it in any auto part store.
i find them in dealer but they cost $8 !!! per bulbs. and i need around 5 of them.
thanks !!
Old Jan 3, 2007 | 12:35 PM
jdm_bones's Avatar
Just check all of them, it would be a good idea to do so! My .02 cents...
Old Jan 3, 2007 | 08:43 PM
aandrewcc's Avatar
i know it is the bulbs for sure
but the bulbs are soo exspensive
rosscaboss
Aug 21, 2007 06:22 PM
cutelilvi3tboig
Nov 4, 2004 09:25 PM
ieatrice
May 3, 2004 03:10 PM
clutch33
Mar 23, 2004 06:14 AM
