Integra - type R engine
Old 10-01-2002, 03:43 PM
NyteTyme2002's Avatar
Default Integra - type R engine
Hello,
I was wondering if anyone has ever tried to put an acura integra type R engine into a regular integra. I was thinking of doing this but I am not really sure if it would work well. Please inform me of any problems that I may have and also if it is not too bad of a thing to do I need to know somewhere that I could either swap for one and also where to get it installed (too big of a job for just me)
Thanks a lot
peace
REPLY TO BOTTOM STATEMENT
THATS A GOOD POINT THAT AN LS WITH TURBO IS JUST AS GOOD OR EVEN BETTER THAN THE TYPE R BUT WHAT ABOUT PUTTING A TURBO IN THE TYPE R ENGINE THAT I WANT TO GET AND BUILDING IT UP TOO, (THIS IS WHAT I WAS PLANNING TO DO) ---SOUNDS GOOD OR BAD????
[Modified by NyteTyme2002, 5:27 PM 10/2/2002]
Old 10-01-2002, 03:46 PM
piatl7il77's Avatar
Default Re: Integra - type R engine (NyteTyme2002)
need to know more info moddel type what your plans are. ect ect.
Old 10-01-2002, 03:53 PM
Default Re: Integra - type R engine (piatl7il77)
I haven't picked up the car yet but I was looking at putting the new engine into either a 1995 LS or GSR
everything would still be stock I am gonna start with the engine
Old 10-01-2002, 04:03 PM
Dream_Seeker's Avatar
Ya it will work no problem at all
Old 10-01-2002, 04:05 PM
Default Re: Integra - type R engine (Extreme_502)
seen, that is good to hear
thanx a lot
peace
Old 10-01-2002, 04:10 PM
New User
TimoneX's Avatar
Yes it works. The GSR in particular is easy to Ratize. The LS, GS, RS, & SE are without Vtec so you'd need to do some work, but it's definately do-able. If you get a GSR though, I don't think there's much value in getting an entire B18C5 engine swap. I'd much rather build the B18C1 in it.
Old 10-01-2002, 04:13 PM
sutrusu's Avatar
Default Re: Integra - type R engine (TimoneX)
what's the difference if it has vtec?
[Modified by sutrusu, 1:13 AM 10/2/2002]
Old 10-01-2002, 04:34 PM
piatl7il77's Avatar
Default Re: Integra - type R engine (sutrusu)
if i has vtec already then you dont have to run the wires to the ecu.
Old 10-01-2002, 04:35 PM
oh i see
[Modified by NyteTyme2002, 1:35 AM 10/2/2002]
Old 10-01-2002, 04:54 PM
New User
TimoneX's Avatar
Yes you'd need a compatible ECU. I'd go with a P28 OBDI and Hondata for this.
Old 10-01-2002, 05:26 PM
04accordV6's Avatar
I'll tell you this before someone comes in here and starts flaming all over you. Everyone would probaly tell you that it's not worth it, 4800 is alot u rather find yourself a gsr and built it up and it'll beat the type r with the amount to invest in it. gsr(around 3300) so u have 1500. hell you could put that towards builting ur tranny up jdm type r final drive, lighten flywheel, clutch, etc.
If you have an LS or b18b1 people are going to say go turbo or ls/vtec.
I can't lie the type r(b18c5) is a really good motor with alot of potential, but i just hope that you are going to spend alot of money on it or it's a complete waste. If i have the money I'd do it.
Old 10-01-2002, 05:44 PM
New User
TimoneX's Avatar
Default Re: Integra - type R engine (95integraLS504)
Since he mentioned it. Turbo IS the way I'd go. For around the same cost of that B18C5 transplant you could look for a turbo setup that'd almost certainly yeild better results.
CW-ITR
12-15-2015 12:30 PM
Jap_Spec_Imports
07-14-2009 06:10 PM
Charismatica
02-19-2008 04:10 PM
white rocket
09-14-2004 10:26 PM
Quick Reply: Integra - type R engine
