Integra Rear mount for B18c swap
I just swapped a jdm b18c into my 98 integra gs. I’ve been having trouble finding the rear T mount for it. I tried the one that came with the car and the two bottom bolts didn’t line up. Tried a gsr one and had the same issues. Any ideas or brands I should try to get the right fitment??
Re: Integra Rear mount for B18c swap
There are only two rear "T" bracket part numbers for ALL '94-01 Integras regardless of what engine is installed... one if for an Automatic transmission and the other is for a Manual transmission. If you are in fact attempting to use the correct "T" bracket, and it seems that the lower holes in the transmission do not line up, you will need to loosen the two upper bolts (one thru the block and the other thru the rear mount) slightly and then rock the engine back and forth to align the bolt holes with the lower part of the "T" bracket.
