92 gsr shaking very bad under wot
ok guys heres whats up.Car has 2 new axles and nothing is loose or bent with the suspension,but under half or wot the car shakes and virbrates really bad do you guys have any suggestions if i left something out that you need to ask......do so and i'll answer thanks in advance
Re: 92 gsr shaking very bad under wot (1SOL2NV)
does it still vibrate after you get to speed and let off the gas? did this problem start after you put in the new axles? where did you get the axles from?? rebuilt?
my guess is that one of your axles or both are bad. I changed out one axle a few weeks ago and the replacement rebuilt axle did exactly what you are describing. took it back, got another rebuilt axle from them and all is fine.
Re: 92 gsr shaking very bad under wot (kkim)
um the car doesnt do it execpt when throttle is applied. it was an advance axle so i think its a rebuild
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 1SOL2NV »</TD></TR><TR><TD CLASS="quote">um the car doesnt do it execpt when throttle is applied. it was an advance axle so i think its a rebuild</TD></TR></TABLE>
exactly what I was experiencing. if it came from a parts store, they could have a lifetime warrenty on the axles. check and if they do, determine which one is bad and return it and get another one.
