Installed VAFC: settings are not saving
Old Dec 6, 2002 | 05:40 AM
TroyL's Avatar
Default Installed VAFC: settings are not saving
I just installed my Apexi VAFC last night and everytime I turn the car off the main settings erase. Like the sensor type, car type, etc. I must have wired something wrong. Everything looks like it works fine except that. Vtec, throttle, pressure, rpm all work fine. I think it might be one of the IG power wires. Any suggestions? Thanks
Old Dec 6, 2002 | 05:49 AM
PM-Performance's Avatar
Default Re: Installed VAFC: settings are not saving (TroyL)
uits not hooked up right, check the power and see if its hooks to the right pin
Old Dec 6, 2002 | 06:07 AM
TroyL's Avatar
They gave 2 IG Power wires. A orange and a red. Do they both go on the same pin? Thats where I got confused
Old Jul 12, 2003 | 10:29 PM
C_I_V_I_C's Avatar
I dunno if it too late but the orange and red do have to go to the same power line, think the orange one has to go closer to the ecu. Might not really matter but .. better safe.
Old Jul 13, 2003 | 08:32 AM
tilt's Avatar
Default Re: Installed VAFC: settings are not saving (C_I_V_I_C)
the two grounds have to be spaced apart. the two power wires dont.
Old Jul 13, 2003 | 05:45 PM
AzG35's Avatar
Default Re: Installed VAFC: settings are not saving (tilt)
You must have your Initialization setting on Yes. Change it to No. This is in the ETC section, under Initialize All I believe. What that does is resets your settings back to default. Change that, and it should work.
zeroek
Nov 23, 2005 11:51 PM
93NXLUDE
Sep 16, 2003 04:10 PM
emissionsux
Sep 4, 2003 01:23 PM
Ludeboi
Apr 25, 2003 11:27 PM
GreddySi99
Mar 24, 2003 08:56 AM
