installed new fender and it doesnt line up with my door???
Old 09-27-2006, 03:31 PM
* B A N N E D *
Pnoyej6's Avatar
Default installed new fender and it doesnt line up with my door???
ok guys, i replaced my 2000 gsr fender with oem 1999 integra fender and it doesnt lined up with my door. Did i install it wrong. The fender sticks out a little bit. We didnt remove front bumper just sideskirt. Please hel me align,
the new fender is oem clean no dents so it should be perfect fit like my old one.
Old 09-27-2006, 03:33 PM
S1NFUL RL1 619's Avatar
Default Re: installed new fender and it doesnt line up with my door??? (pnoytegn707)
did you make sure you made those fine adjustments while you were installing it? or did you just slap the bitch on there?
Old 09-27-2006, 03:38 PM
* B A N N E D *
Pnoyej6's Avatar
what fine adjustments? Oh i just slap it on there
Old 09-27-2006, 03:46 PM
Default Re: (pnoytegn707)
well i don't do body work... but with anything that you build/install you don't tighten anything so you can correct the alignment and placement of things. i'm pretty sure it would be the same when you're installing anything that requires precision fitment. so loosen up those bolts and get that fender lined up then tighten everything down.
can anybody else back up what i just said? like i said, i don't do bodywork. so if i'm incorrect, let me know the correct way as well.
Old 09-27-2006, 03:59 PM
-Todd-'s Avatar
Default Re: (S1NFUL RL1 DB7)
You cant just put a body part on and expect it to be perfectly flush without adjusting it.
Old 09-27-2006, 04:51 PM
ingrate's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by S1NFUL RL1 DB7 &raquo;</TD></TR><TR><TD CLASS="quote">well i don't do body work... but with anything that you build/install you don't tighten anything so you can correct the alignment and placement of things. i'm pretty sure it would be the same when you're installing anything that requires precision fitment. so loosen up those bolts and get that fender lined up then tighten everything down.
can anybody else back up what i just said? like i said, i don't do bodywork. so if i'm incorrect, let me know the correct way as well.</TD></TR></TABLE>
Sounds about right. I did the exact same thing installing a fender on my uncle's acura vigor.
Old 09-27-2006, 05:08 PM
phateless's Avatar
i installed a fender on my LS and you gotta keep all the bolts loose and expletive with it until it's right. mine looks perfect, it's really impossible to tell that it's ever been messed with.
Old 09-27-2006, 05:10 PM
HONDACURA-DB8's Avatar
Old 09-27-2006, 05:11 PM
How did the paint job turn out on your fender?
Old 09-27-2006, 06:26 PM
phateless's Avatar
i lucked out and managed to find a pre-faded milano red fender off of the exact same year, color, and model as my car. gotta love ebay.
Old 09-27-2006, 07:47 PM
* B A N N E D *
Pnoyej6's Avatar
Default Re: (phateless)
it matched perfectly. Hey db8, how much will Vlad charge to rebuild my block with new pistons, headgasket, rods,arp headstuds, .5mm bored over. I wanna build my block to handle more boost, since im loosing oil
Old 09-28-2006, 12:46 AM
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by pnoytegn707 &raquo;</TD></TR><TR><TD CLASS="quote">it matched perfectly. Hey db8, how much will Vlad charge to rebuild my block with new pistons, headgasket, rods,arp headstuds, .5mm bored over. I wanna build my block to handle more boost, since im loosing oil</TD></TR></TABLE>
Stop by the shop so we can talk it over and give you a quote in person...
Blue Horiz0n
11-07-2009 04:00 PM
ps004ynos
Paint and Body
02-09-2009 07:19 PM
HyRev
11-10-2008 11:51 AM
dayvid05
08-05-2008 01:54 PM
SL!M
06-05-2003 12:12 PM
Quick Reply: installed new fender and it doesnt line up with my door???
