quick injector question!
Old Aug 28, 2011 | 12:09 PM
LS_VTECteggy's Avatar
Default quick injector question!
Hey guys I think I just jumped the gun and bought 240cc injectors. I bought them for the purpose of passing my inspection and I'm not sure if they will work. The guy that I bought them from says it came out of a 94 ls. I have a 99 teggy ls/v-t and was planning on running on these injectors for a day or two tripping all sensors and then going in for an inspection. Right now im running 450cc obd1 injectors so I had to rewire my clips to obd1 clips and they're peak and hold injectors. My question is with that being said will these injectors work with my obd2 ecu? I think I read somewhere that with obd1 clips and injectors the obd2 ecu won't give off a signal for it to fire off. Please help my registration ends friday so this car need this inspection fast thanks guys
Old Aug 28, 2011 | 12:23 PM
mouab18c1's Avatar
Default Re: quick injector question!
You said your injectors are wired for obd1 clips then it's all plug and play now. All B series are 240cc, just different clips.
Old Aug 28, 2011 | 12:36 PM
so if I plug it in the resistor box will still be ok and the obd2 ecu will work just fine?
Old Aug 28, 2011 | 09:17 PM
mouab18c1's Avatar
You don't need the resistor box for those injectors and yes the obd2 ecu is fine.
thaiphob
Aug 4, 2017 10:40 AM
jayswizz
Feb 14, 2014 10:06 AM
vlc92189
21
Mar 6, 2009 12:06 PM
chris@allmotor.net
Oct 19, 2003 04:39 PM
aesthetics82
Apr 2, 2003 05:39 AM
