Indecisive engine swap
Old Jan 6, 2014 | 06:56 PM
Flipmonkey's Avatar
Default Indecisive engine swap
What up guys . I blue my LS motor and I can't decide what engine to put in now . I was thinkin b20 . But everyone's expecting that, and I'm trying to stay away from a k20 . Are there any other good ideas ???
Flipmonkey's Avatar
Blew *
Old Jan 6, 2014 | 07:02 PM
drmix's Avatar
Default Re: Indecisive engine swap
Most important question is what is your budget and what is your goal? A gsr swap should be a good choice and is decently priced.
Old Jan 6, 2014 | 07:12 PM
B_Swapped93's Avatar
B20V... overbore 1mm 11:5:1 pistons/eagle H beam rods, tuner 3 cams, ultra series manifold, 76mm tb, toda rep header, and a 3'' exhaust. that set up would be good for 225+whp.
Old Jan 6, 2014 | 08:47 PM
Flipmonkey's Avatar
Well if i were to get a b20 . I was thinking boosting . But idk how fast I wanna go
Old Jan 6, 2014 | 08:48 PM
Flipmonkey's Avatar
I'm thinking if I go b20 . To boost it
Old Jan 7, 2014 | 02:54 AM
Wannabe JDM's Avatar
let's start with the speed limit. besides that what are your power goals?
Old Jan 7, 2014 | 03:29 PM
supersilverdc2's Avatar
First of all , b20s are not ideal in the boost world on stock sleeves, they are thin.... Second of all what hp are you looking into...
If the Ls block is salvageable get a gsr head and do an lsvtec setup, then boost. You will see waaaay better numbers and power.
Just make sure you build the bottom. I did ls rods but I had them shot peened to strengthen them, then ACL yellow race bearings is a must along with arp headstuds.
Old Jan 7, 2014 | 05:55 PM
$MIKE$'s Avatar
B18c built for boost.
I if you have the money k20 but that can be $$$
Old Jan 8, 2014 | 05:48 PM
minimarine09's Avatar
from everything that im reading the gsr b18c1 is an all around great motor for boost as long as the compression is lowered to like 9.0:1 right? im new and coming from the 4g63 world so please dont flame me for a dumb question im learning
also, dont mean to post jack but is there be any difference between a ls/vtec (b18b with a b18c head) and just getting a b18c long block? in other words, is there a difference in the short blocks? i.e oil passages? or something
Old Jan 8, 2014 | 06:12 PM
no you can safely push 300whp on stock internals after that you start to risk it, thus forged internals become necessary. Nope 9:1 would be ideal but heck some ppl boost ITR engines any where from 10:6:1 to 11:1:1 for the jdm itr, it's not recommended tho. Yes there are different oil passages I'm not sure how many but for an LSV you need to run a line from the filter plate to the head. along with a few other differences 87v89mm crank, oil squirters rods/pistons.
Old Jan 8, 2014 | 06:27 PM
awesome! i think i would just like to stick with 9.0:1 just to be safe if i were to build the block and just boost the crap out of it lol, after all, the compression does is help the power while not in boost, but after boost hits, its obsolete.
so if i were to get a usdm integra gsr that comes stock with 10.0:1 CR i can just throw a turbo on and boost to around 300 hp and be alright? reliable dd? not beaten on everyday of course, i dont go WOT unless someone provokes me... lol
Old Jan 8, 2014 | 06:44 PM
$MIKE$'s Avatar
If your gonna use forged internals 9.0 is old school with e85 and advances to tunning why not 10-10.5 comp?
I had a stock block Itr motor (USDm 10.6:1) I had boosted on 15 pounds for a while did fine like that. It was about 390 whp
Old Jan 8, 2014 | 06:47 PM
$MIKE$'s Avatar
awesome!
You should be fine for a good bit but it's not gonna be reliable as stock nothing will. And it won't last forever
Old Jan 8, 2014 | 06:50 PM
i would be going with 93 pump, but i guess you are right about the advances to tuning i should be solid, no knock then no problem lol can i PM one of you guys some questions that i have so i dont drive this post farther off topic than it already is?
and to the OP, coming from the new guy, if its worth anything, go with the b18c1 lol
Old Jan 8, 2014 | 07:01 PM
Flipmonkey's Avatar
All in all I wanna see how far I can go with hp . I plan on boosting and then rebuilding to top my previous build . I'm new as well , I just wanna see how strong a integra can pull
Old Jan 8, 2014 | 07:54 PM
how much money do you have ? turbo k24 all the way y0
yes srs
Old Jan 8, 2014 | 10:45 PM
standy xsi's Avatar
12a rotary
Old Jan 9, 2014 | 12:19 AM
m4xwellmurd3r's Avatar
Originally Posted by standy xsi
12a rotary
With a delorto side draft. And boosted
1994delsolLS
14
Jan 6, 2025 10:55 AM
TeamRPM_ZC
Apr 27, 2008 12:17 PM
sergionuneschang
Apr 23, 2004 08:13 AM
4drRacer
Sep 3, 2002 06:07 PM
burnett999
21
Aug 23, 2002 09:25 AM
