improving power on b18b
Old May 22, 2002 | 04:20 PM
Cuong-nutz's Avatar
Default improving power on b18b
what other ways are there to improve power in the b18b without boosting it
other ways beside nos, i/h/e
TIA
Old May 22, 2002 | 04:25 PM
zilverz's Avatar
Default Re: improving power on b18b (wheresmyvxhb)
TIA
High compression
Bored cylinders / oversized pistons
Vtec head
Ported and polished head
Camshafts/ tuning
Fuel components/tuning
Performance ignition
Lighten the rotating mass: Light weight rods / Light weight crank / Pulleys
ECU tuning
Old May 22, 2002 | 05:22 PM
Cuong-nutz's Avatar
Default Re: improving power on b18b (zilverz)
can i swap the intake manifold with like a gsr or r?
and if so what are the gains?
[Modified by wheresmyvxhb, 8:23 PM 5/22/2002]
Old May 22, 2002 | 05:23 PM
harryg's Avatar
b16 head
Old May 22, 2002 | 05:27 PM
Cuong-nutz's Avatar
Default Re: improving power on b18b (harrytg)
and no ls/vtec
i dun wanna mess with that
keeping it ls no vtec
Old May 22, 2002 | 05:38 PM
non-VTEC's Avatar
cams, cam gears, FPR and dyno tuning........
Old May 22, 2002 | 05:44 PM
Halo's Avatar
Default Re: improving power on b18b (non-VTEC)
I would also add obd 1 ecu upgrade and a full headport
Old May 22, 2002 | 05:54 PM
Cuong-nutz's Avatar
Default Re: improving power on b18b (Halo)
would i gain anything swappin in a gsr intake manifold?
Old May 22, 2002 | 06:02 PM
non-VTEC's Avatar
no you would probably loose power plus it's not a dicrect bolt on.
if you want to change your intake manifold look into the skunk2 manifold for the B18B1 head. it flows very good and will compliment a set of aftermarket cams really well.
Old May 22, 2002 | 06:45 PM
BlowOff's Avatar
New User
JG Edlebrock (spelling?) makes the Victor X manifold for the LS. It is nice.
You could also go with a bigger throttle body.
Advance your timing...a few degrees.
Get an Apexi SAFC and tune your fuel curve.
Light weight pulleys.
Old May 22, 2002 | 07:09 PM
SIK IN DA HED's Avatar
New User
Default Re: improving power on b18b (BlowOff)
i recommend gettin the skunk2 intake manifold. they are $250 and give you nice power at high end. you can always build your head but its not the best bang for your dollar. i would swap out your tranny for a gsr tranny. that also does wonders.
Old May 22, 2002 | 07:13 PM
BlowOff's Avatar
New User
Default Re: improving power on b18b (dlplayboy)
Oh! Don't forget you can get a light weight flywheel.
Old May 22, 2002 | 07:32 PM
sutrusu's Avatar
wow... i wanted to see a post just like this. i am in the same situation. right now i have a obd1 b18b with an s80 tranny. here is the order of stuff i am gona do to it. right now it has advanced timing, tightened throttle cable, apex'i filter on stock piping, tanabe racing medallion exhaust, ngk plugs and wires, and i use mobil 1
i plan on getting soon (in this order)
nice flowing header (4-2-1)
test pipe
cam gears and tuning
this is reasonable stuff. after that maybe a gsr tranny to make shifting better?
im gona bookmark this thread and see what everyone else says. how easy is the skunk2 manifold installation? hopefully it comes with instructions...
[Modified by sutrusu, 4:34 AM 5/23/2002]
Old May 22, 2002 | 07:59 PM
AzN_Flava's Avatar
get a good tranny
Si tranny or R tranny
9lb flywheel
no exhaust or something i forgot the last one
14.7 quartermile..
your a lot faster with the stock engine without any power gains
Old May 22, 2002 | 09:11 PM
maxxdout's Avatar
Default Re: improving power on b18b (AzN_Flava)
most people have filters on a stick...get a true CAI first off. of course exhaust and header. Beware of lightened flywheels, some arnt as strong as stock units or high end units.
If any guys with LS's are running Skunk2 IM's how bout some feedback, first time i was aware that one was made for our models. Would love to hear about results.
Old May 22, 2002 | 09:36 PM
dubster99's Avatar
Default Re: improving power on b18b (maxxdout)
Nitrous
Old May 23, 2002 | 05:48 AM
Cuong-nutz's Avatar
Default Re: improving power on b18b (dubster99)
nitrous is not my thing
Old May 23, 2002 | 08:19 AM
KRiS1's Avatar
does the top end power that the skunk2 manifold makes come at the expensense of low rpm power and torque?
[Modified by POS Hatchback, 9:20 AM 5/23/2002]
Leimokei's Avatar
New User
for bolt on...cai, header (hybrid 4-2-1 with longer secondaries http://www.hytechexhaust.com) 2.25in Exhaust all the way back...(high flow cat)T/B bored to 2mm larger than stock, skunk2 intake manifold, some crower cams, street port your head..and up the compression on the pistons..lighten flywheel, lighten the car, Si or GSR or R w/LSD...
Old May 23, 2002 | 09:38 AM
qtiger's Avatar
Default Re: improving power on b18b (POS Hatchback)
Yep. The losses shouldn't be that extreme with a b18b, because you aren't losing secondaries like the b18c does.
I would recommend against the Victor-X manifold, especially with a b18b. Your engine doesn't rev up that high and will require a heavy set of mods to do so safely.
Old May 23, 2002 | 09:41 AM
KRiS1's Avatar
Default Re: improving power on b18b (qtiger)
Im thinking about putting one on my b20Z which is similar to the B18B and I have to replace the manifold anyways.
juanintec
Aug 21, 2009 06:05 PM
Rooftop voter
Jun 26, 2007 05:17 AM
Greenery18
15
Feb 21, 2007 07:11 PM
Bantam
Feb 18, 2004 03:54 AM
B_1_8_hatch
Mar 21, 2003 09:29 PM
