im question
Old Oct 3, 2005 | 07:09 PM
mrdeadman's Avatar
They let me pick
Default im question
are the skunk2 proseries complete bolt on kits? you just switch all the sensors over and bolt it back on? or do i have to do something else? also does it come with everything like the throttle body or do i switch the tb off the stock one? thanks oh yeahm, will it work with any cai or do i have to run a different size pipe for the cai? is the intake diameter the same as factory?
Old Oct 3, 2005 | 08:52 PM
Kendall's Avatar
It's a bare manifold, that's it. You'll need to reuse all of your sensors and your original throttle body. Also invest in intake manifold and throttle body gaskets (perfect time to upgrade to a Hondata gasket). If you have an LS you can use your current intake, but if you have a GSR you'll need to invest in an LS or ITR intake.
Old Oct 4, 2005 | 01:08 PM
mrdeadman's Avatar
They let me pick
Default Re: (Kendall)
the skunk 2 is 100% bolt on right, like an exhaust or header?
Old Oct 4, 2005 | 01:15 PM
WH0R3nEF9's Avatar
Default Re: (mrdeadman)
yes, it's a bolt on.
Old Oct 4, 2005 | 01:25 PM
mrdeadman's Avatar
They let me pick
Default Re: (1SiKTeG)
sweet thanks.
ReillyEK
Mar 7, 2013 08:45 PM
slayer423
Aug 29, 2012 05:40 AM
89MA70
Jul 7, 2008 07:58 PM
dave24
Jan 5, 2006 05:13 PM
Ls InTeGrA RaCeR
Apr 19, 2004 09:02 PM
