idle problems/issues
ok i swap out the b18a im for a 94 im when i go start/warm my car cold it idle at 1k and stay warm at 1k any ideas bout this problem.Maybe tps or the iacv dont know thanks
ps i took the iacv out and cleaned it maybe i screw something to tight
https://honda-tech.com/zerothread/1564019
i did that i think i tighten that white screw to tight real tight
Modified by jdmboi86 at 11:31 PM 1/3/2007
Thats the FITV, not the IACV. Its possible you got the TPS and IACV plugs backwards, but the car will run like crap if you did that. Unplug the IACV (when warm) and set the base idle to 600 or so. Then plug the IACV back in and it should idle up to 750.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by 95 integra »</TD></TR><TR><TD CLASS="quote">Thats the FITV, not the IACV. Its possible you got the TPS and IACV plugs backwards, but the car will run like crap if you did that. Unplug the IACV (when warm) and set the base idle to 600 or so. Then plug the IACV back in and it should idle up to 750.</TD></TR></TABLE>
jEE
10
Mar 3, 2011 01:02 PM
6thgen4u2nv
11
Jan 11, 2004 03:19 PM
