Idle problem.... please help
Old Jan 21, 2003 | 08:16 PM
volkracing99's Avatar
New User
Default Idle problem.... please help
After I change my thermostat, the car sometimes idle so rough, between 1100 to 2300 rpm. But, sometimes also idle at 2200 and stay here.... if I let the engine running, the idle after 15 minutes will go down to 1100....
Does any one know why.... and how to fix it...
Thanks...
Old Jan 21, 2003 | 08:19 PM
97hb's Avatar
Default Re: Idle problem.... please help (volkracing99)
Any cel's??? Did you reconnect the coolant temp sensor??? Could also be the iacv.
Old Jan 21, 2003 | 08:23 PM
New User
Default Re: Idle problem.... please help (97hb)
97hb:
What mean by any cel's??
for the coolant temp sensor I make it always on(the fan)
and sorry, what is iacv?
Thanks
Old Jan 21, 2003 | 08:26 PM
Buckshot's Avatar
cel = check engine light
97hb's Avatar
Cel's stand for check engine light. The IACV is the idle air control valve located on the back of the intake manifold. Usually they will crude up and start messing with your idle.
Old Jan 21, 2003 | 08:29 PM
New User
Nope... no cel...
and the IACV also in the good position...
could be anything else?
Old Jan 22, 2003 | 07:22 AM
zilverz's Avatar
Nope... no cel...
well coolant does run through the IACV and the Throttle body ... check your coolant level in the radiator ... now that its ran and pump some more coolant through ... how well is the temp gauge working ? is your fans kicking on ?
Old Jan 22, 2003 | 11:32 AM
New User
how to check the IACV ?
Old Jan 22, 2003 | 12:34 PM
maxxdout's Avatar
had the same prob. Add coolant, and open bleeder screw to get air bubbles out. The thermo. cant register the temp of steam so be sure all the bubbles are gone.
Old Jan 24, 2003 | 07:45 PM
New User
I fixed my idle problem... thanks to all of you who has been trying to help me, especially to newgsrdriver , it was my Fast Idle Thermo Valve....
BUT, look what happend to me on the way back,
the lady in front of me make a suddent STOP....
sohcpower1
May 22, 2016 10:09 AM
blazzer
32
Apr 8, 2014 11:37 AM
H22Honda98
Sep 5, 2007 05:51 PM
Eurasia00
Apr 22, 2002 11:37 AM
