Idle problem please help
Old May 10, 2010 | 07:02 PM
USMC_RussianNVP's Avatar
Icon7 Idle problem please help
Im having a problem with my 94 Integra LS that has to do with the rpms normally staying around 1500-2000 rpms when driving. This occurs until i tap the gas pedal then it drops to almost normal level around 1k. Please help it is so annoying to tap the gas peddle every time i come to a stop....
Old May 10, 2010 | 07:53 PM
JDM-LuxurySport's Avatar
Default Re: IDLE PROBLEM PLEASE HELP
Ya dumayu kakoyta sensor slamalsa ili tros ot gaza zastrivaet. U menya tozhe inagda tros zastrivaet.
Old May 10, 2010 | 08:04 PM
Apathy47's Avatar
most likely a dirty Idle Air Control Valve
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
BUT if that doesn't fix it, maybe it's a dirty Fast Idle Thermo Valve if you have a 94-95 GSR or an Automatic motor.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old May 10, 2010 | 08:20 PM
Thank you guys Ill get cracking on it tomorrow hopefully
Old May 14, 2010 | 09:19 PM
Default Re: Idle problem please help
I have a 94 ls integra and I have the same problem with my rpms at normal temp staying around 1200-2000rpms. This occurs until i pump the gas really quick then it goes to about 750-1000rpms.
I have taken and cleaned both IACV and FITV. It feels a little better than before but it still didnt solve my issue. I didnt screw in the center all the way down. it was a about 3 revolutions counterclockwise from the bottom. It took about 3 revolutions to install it back to the original position.
Should i have screwed it in all the way down and if I screw it down all the way is it going to drop below the 750rpms when the vehicle is at normal temp?
Also When i took apart the IACV cleaning the inside became to be a challenge since i could still see the carbon build up even after spraying it with brake cleaner. Almost used the whole bottle trying to clean it out lol. It looked much better just dont know if I was able to clean it as well as it should of been cleaned.
Old May 15, 2010 | 10:32 AM
WOW I FINALLY FOUND THE PROBLEM. LOL The throttle cable was a little tight which caused the throttle to stay open just a hair. Thanks for everyones help. Cleaning the IACV and the FITV was good to do regardless. Thanks again everyone
itzurboy3
May 26, 2010 11:23 PM
Kirk@SyndromeAuto
Jan 31, 2007 08:45 PM
jaydoghondacivic25
Jan 29, 2006 07:55 AM
rdeezy25
May 17, 2005 01:55 PM
SLOAZZ95
Nov 5, 2003 04:42 PM
