idle problem
Old May 10, 2010 | 09:23 AM
itzurboy3's Avatar
Default idle problem
when it gets hot or ive been driving for awhile my rpm drops down to 500 and then jumps back up to like 700 or 800 and then i turn my lights on and its goes back to normal for like 15mins and then it stars again what could be the problem
Old May 10, 2010 | 06:33 PM
itzurboy3's Avatar
Default Re: idle problem
anyone
Old May 10, 2010 | 06:44 PM
Apathy47's Avatar
most likely a dirty Idle Air Control Valve
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2Ahow-clean%2A%2A%2A-your-iacv-k-idle-air-control-valve-1575913/
BUT if that doesn't fix it, maybe it's a dirty Fast Idle Thermo Valve if you have a 94-95 GSR or an Automatic motor.
https://honda-tech.com/forums/acura-integra-6/%2A%2A%2A-how-%2A%2A%2A-clean-your-fitv-aka-fast-idle-thermo-valve-1564019/
Old May 10, 2010 | 06:49 PM
itzurboy3's Avatar
ima check the iacv tomorrow n im ls not gsr n im not automatic
Old May 18, 2010 | 07:56 AM
itzurboy3's Avatar
bump i cleaned iacv and nothing made it worse now it just stays at 500 rpms instead of going up a little
Old May 26, 2010 | 05:03 PM
sloweredcivic's Avatar
i am having this exact same problem...any word on what the issue was/is?
Old May 26, 2010 | 06:13 PM
SleeperGSR's Avatar
so you might wanna reset your ecu now that it's clean. Maybe that will help. the only other thing i can think of is check plugs wires dizzy anything easy that you can rule out.
Old May 26, 2010 | 08:23 PM
truKalypso's Avatar
check your grounds
Old May 26, 2010 | 11:23 PM
vroomvroomparty's Avatar
How old is your car? From personal experience, its a TPS, unfortunately aftermarket ones are total crap, so just go get a throttle body with a fixed TPS. The IACV cleaning is good, now just a timing adjustment, a fuel filter and youre set!
ryanhauk
May 20, 2009 06:42 PM
Thatssojdm
Aug 5, 2008 07:59 PM
civc_tt
Jul 30, 2006 11:00 AM
BOOSTED_JDM_DB8
Feb 3, 2006 01:01 AM
bob16ost
Feb 10, 2004 11:41 AM
