idle problem?
Old Feb 11, 2004 | 08:07 PM
smkngsr's Avatar
Default idle problem?
i cant seem to figure out whats wrong with my car...why does my idle go really low like 500...really low but then it only happens when the car reach the right temp and stopping on the traffic light...thanks much
Old Feb 11, 2004 | 09:03 PM
mugen92acintls's Avatar
Default Re: idle problem? (smkngsr)
You probably have to do a simple idle adjustment. If it does this especially with the headlights one then pop the hood, look for a small set screw on throttle body, use flat head screw driver and adjust the idle to 700-800 RPMs at normal operating temp. Try that it should be better.
Old Feb 11, 2004 | 09:07 PM
crazzeboost's Avatar
This may sound a little wierd but one time when my radiator was low on fluid i had this problem with my idle but it kinda went away when the car was warmed up, kinda off but wanted to see if i could help.
Old Feb 11, 2004 | 10:08 PM
nexus da9's Avatar
Default Re: (crazzeboost)
yeah, i'm kinda getting the same problems as you, but my check engine light comes on, =*\... my da is saddening me... what's wrong with my car??? help mee!!
Old Feb 12, 2004 | 09:21 AM
smkngsr's Avatar
Default Re: (nexus da9)
i will try that turning the screw on throttle body...and if not then i will get my iac valve clean out...hope this will do some changes...
dlncooke
Honda Fit
Apr 7, 2013 08:05 PM
gutted-dx
Dec 18, 2005 09:08 PM
R. Mack
Jun 1, 2005 07:55 PM
VtecInteg95
Dec 15, 2002 06:29 PM
Ideal
Aug 22, 2002 08:51 PM
