jumping a car, with reversed cables, doh
my friend accidently jumped my car by putting the negative on positive and needless to say it blew my battery fuse, but now my car is having some electrical problems. At idle it will raise revs will fo up/down searcing for about 900rpm and when i turn off the lights or radio it will be fine. And when i give it any throttle over about 60% the car will bog. I went and got the alternator tested and battery and both are working fine. Could this have messed up any other sensors/fuses that would cause these problems?
thanks
thanks
Re: jumping a car, with reversed cables, doh (xx dc2teg xx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by xx dc2teg xx »</TD></TR><TR><TD CLASS="quote">yes ecu could be done,
next time make sure u be careful--you do know your battery coul've exploded and acid all over </TD></TR></TABLE>
i agree... consider urself lucky if a dead ecu was the only damage. but good luck tho... i hope u find out the problem.
Re: jumping a car, with reversed cables, doh (BlackSage)
sounds like someone went driving without a hood
consider yourself and your friend really lucky because battery acid and anything it touches does not mix
bigslimdog
03-30-2004 03:07 PM
