idle dropping
Old Sep 5, 2007 | 10:09 PM
driftahboi's Avatar
Default idle dropping
i noticed today while i was leaving from school my idle seemed to go down like it was about to die out. i wasn't in gear, i was on nuetral and i had my foot applyed to the brakes. all of a sudden it seemed to just drop like about the 350-500 range then it seemed to just go up normally around the 600-750 range. jus want some feedback if anyone has experienced this problem. or if something is wrong with my car. thanks!
-kev
Old Sep 6, 2007 | 06:02 AM
OLD-HONDA's Avatar
Default Re: idle dropping (driftahboi)
I have the same exact problem, but sometimes mine just drop all the way to 0 & just shuts off. let me know how you fixed it...
Old Sep 6, 2007 | 10:35 AM
wat2y's Avatar
I have that problem sometimes but that's only when my a/c is on. Is your car at normal operating condition when this happens?
Old Sep 6, 2007 | 12:01 PM
riddlinkid1986's Avatar
Default Re: idle dropping (wat2y)
bump! same issue yo!
Old Sep 6, 2007 | 01:01 PM
Tha_liks's Avatar
Well a quick fix to help that idle issue use a flat screw driver and adjust the screw on the side of the throttle body, that will open it a little more so your car gets some air. But to really fix it for good clean your IACV.
https://honda-tech.com/zerothread?id=1575913
Old Sep 6, 2007 | 05:23 PM
driftahboi's Avatar
Default Re: idle dropping (Tha_liks)
g thanks that was alot of help. never have that problem today but ill see to it in the future to clean it out
Old Sep 6, 2007 | 05:51 PM
SleeperGSR's Avatar
From reading on here, the school of thought is not to touch that screw and to just clean your IACV. That should solve the problem. I haven't done this ever or had the problem, however, my car is a 96 and i will be cleaning this soon cuz it probably never has been. There should be a good DIY to follow in the search somewhere.
Old Sep 6, 2007 | 11:09 PM
keeks707's Avatar
thanks for the info..i have the same problem..ima try it and ill let u guys know how it goes!
dc97
Nov 8, 2012 01:49 PM
philep_cb7_91
Feb 21, 2010 11:28 AM
chhonda150
May 4, 2008 05:06 PM
SpeedMachine
Dec 9, 2005 02:55 PM
g-love
Jun 11, 2002 09:04 AM
