iacv question
Old Sep 26, 2005 | 01:10 PM
FROSTDC2's Avatar
Default iacv question
will a obd1 control valve fit a obd2 plug?
Old Sep 26, 2005 | 01:57 PM
FROSTDC2's Avatar
Default Re: iacv question (champ white coupe)
Old Sep 26, 2005 | 09:58 PM
FROSTDC2's Avatar
Old Sep 26, 2005 | 10:01 PM
HARI.'s Avatar
yes it will. it will even fit an obd0
Old Sep 26, 2005 | 10:34 PM
FROSTDC2's Avatar
Default Re: iacv question (DA-HARI)
even tho obd1 gsr iacv is diff from obd2 gsr
Old Sep 26, 2005 | 10:55 PM
HARI.'s Avatar
yeup...trust me bro, the plugs are the same. i have an itr iacv and it plugged in my obd0 wiring harness. they are all the same iacv plugs
Old Sep 27, 2005 | 09:44 AM
FROSTDC2's Avatar
plug doesnt seem to fit and its throwing a check light when b4 on the old 1 it wouldnt??? i dont think plug fits for some reason
Old Sep 27, 2005 | 10:53 AM
HARI.'s Avatar
hmmm... well then, just change the plug to obd1 on your wiring harness
Old Sep 27, 2005 | 03:20 PM
FROSTDC2's Avatar
ok i feel dumb as ****, the 2 prongs were bent and i just straightened them out and it plugged right in, only prob now is that it idles around 1000-1100 but no more misidle , any1 know y it might be idling high?
Old Sep 27, 2005 | 03:50 PM
FROSTDC2's Avatar
Old Sep 27, 2005 | 05:51 PM
Xsi's Avatar
Xsi
Try resetting the ecu, looking for error codes, checking for vacuum leaks etc
Old Sep 27, 2005 | 06:10 PM
FROSTDC2's Avatar
Default Re: (Xsi)
no cels or leaks, ill try resettin the ecu, thanx
Old Sep 27, 2005 | 06:17 PM
memicah's Avatar
Default Re: (champ white coupe)
goodluck with that... errattic idle is annoying...
altoids5987
Dec 18, 2023 08:29 PM
91efbluehatch
Jul 28, 2012 12:23 AM
sumoneEK
Aug 2, 2010 09:29 AM
SpoonyGSR
18
Aug 18, 2005 05:16 PM
gezer
Aug 26, 2004 10:42 PM
