IACV keeps throwing a CEL!!!!!!!!!!!!!!!!!!!!
Old Nov 17, 2006 | 05:33 PM
b18c1dc2's Avatar
Default IACV keeps throwing a CEL!!!!!!!!!!!!!!!!!!!!
i have a 2000 GSR with an AEM V2 CAI, cleaned the filter last week (was very dirty) and figured since its all apart, id clean the throttle body....nothing crazy, just with a clean rag and small brass brush and throttle body/intake cleaner. after putting eveything back together, it idled between 1.5 and 2 grand (up and down), a day later i threw a CEL for my IACV. i reset the computer and it goes away, it seemed to get a little better as the days go on, but when in idle and the car is at NOT, it will throw a light if i dont stay on the gas and dont let it idle by itself. other than that, the car runs VERY strong, very smooth, no flat spots, like its brand new.....only when im at idle ( like at a stop light) it gets all f#cked up. oh yeah, the IACV i got in there now was brand new put in 8 months ago....i dont want to spend another 180 bucks on one.....is there any hope!!!!?????????????? please help
Bryan
everybody on this site has always been very helpful with past problems, that is why i have faith.
Old Nov 17, 2006 | 05:50 PM
Dogginator's Avatar
Daisy... Daisy...
Default Re: IACV keeps throwing a CEL!!!!!!!!!!!!!!!!!!!! (b18c1dc2)
Clean it with carburetor cleaner. I prefer to do it while the IACV is on the car. You remove the intake, start the car, and then spray the carburetor cleaner into the port on the throttle body for the IACV (two holes before the throttle plate, it should be sucking air). This way, the carburetor cleaner actually flows through the IACV to thoroughly clean it. The car will most likely stall when you spray. Leave it sit for a minute before restarting so that the cleaner can dissolve any buildup.
Old Nov 17, 2006 | 05:52 PM
9311dan's Avatar
holy ****!
you might wanna replace the IAC!!!!!!!!1!!!!!@@@!1!!!
aahhhhhh!~!!!!!
Old Nov 17, 2006 | 06:01 PM
b18c1dc2's Avatar
Default Re: IACV keeps throwing a CEL!!!!!!!!!!!!!!!!!!!! (Dogginator)
thanks alot man.....ill give it a try tomarrow.....hopefully it works.......you said ' carburator ' cleaner, right ? dont use what i was using? (just want to make sure....)
Old Nov 17, 2006 | 06:05 PM
Dogginator's Avatar
Daisy... Daisy...
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by b18c1dc2 &raquo;</TD></TR><TR><TD CLASS="quote">thanks alot man.....ill give it a try tomarrow.....hopefully it works.......you said ' carburator ' cleaner, right ? dont use what i was using? (just want to make sure....)</TD></TR></TABLE>
Throttle body cleaner is most likely the same stuff as carburetor cleaner. It is just organic solvents. The key is to make sure that the cleaner flows through the IACV.
Old Nov 17, 2006 | 07:23 PM
POE's Avatar
POE
these IACV threads have been beat to a pulp!
and Carb cleaner is the best, i usally let it dry before i put it back on.. or at least try and get most of the fluid out.
Old Nov 17, 2006 | 08:18 PM
95 integra's Avatar
Default Re: (POE)
How about my infamous "vacuum leak" theory.
KodSol
17
Dec 19, 2011 04:13 AM
EusebioSam19
Jan 10, 2011 06:52 PM
mister.wong
29
Mar 10, 2009 03:24 PM
924doorEG
16
Nov 15, 2007 06:14 AM
fronomo
Aug 28, 2007 03:56 PM
