I need help
Old Jun 13, 2007 | 06:21 PM
92civicx's Avatar
Default I need help
I'm not sure whats wrong with my bro's car one reason is its kind of hard to explain.
When i drive the faster i go from 25mph and up, it gets louder and louder. I thought it was a whole or crack in the manifold or exhaust but their isn't any.
i notice it shakes more and more the faster i go also.
the noise is coming from the passenger side axle area or transmission.
its kind of hard to explain the sound. Its a mixture of a whole in exhaust and something seriously fucked up with the engine
It shakes so bad and is loud enough that i'm not even gonna drive it out the driveway. It seems like its somethings gonna break unless i fix it
Old Jun 13, 2007 | 07:25 PM
92civicx's Avatar
Default Re: I need help (92civicx)
i jacked up the car and the wheel isn't spinning like it should it stops after a lil spin.
like a back and fourth motion.
Old Jun 13, 2007 | 07:41 PM
numbnuts22715's Avatar
are all suspension components okay?
All the lugs all the way tight?
And with it shaking, it could also be the axle, check that out asap.
Old Jun 13, 2007 | 07:47 PM
92civicx's Avatar
Default Re: (numbnuts22715)
axle seems to be ok no leaking or nething like that. What else should i be looking for?
Old Jun 13, 2007 | 08:07 PM
Sam92Teg's Avatar
Default Re: (92civicx)
Just for the hell of it, check to see if you jumped time on the cam gears. If the exhaust valve is partially open during the power stroke, it can get quite loud.
But the rest of you description does sound like a failing inner joint on the axle. You can grab the axle shaft near the inner joint and check for excessive play.
Also check your tranny fluid level and hope that it isn't tranny related.
Old Jun 14, 2007 | 08:58 AM
92civicx's Avatar
Old Jun 14, 2007 | 01:22 PM
92civicx's Avatar
by axle shaft you mean the circle in the middle of the rotor thats kind of a circle but a dent in it, if thats not it let me know and their is no excessive play. And i can't find the damn tranny fluid.
Old Jun 14, 2007 | 07:14 PM
92civicx's Avatar
any suggestions??
painbus
Dec 15, 2009 10:29 AM
Samuels
Aug 4, 2009 11:27 AM
jawsiiv
Nov 10, 2008 03:28 PM
wwang924
30
Oct 9, 2005 06:08 PM
95GSRTT
Aug 4, 2004 10:01 PM
