i/h .. how much will an exhaust help ?
I have i/h right now .. going to put an exhaust int he summer ... will there be a big diffrence i always here how the header is useles without the exhaust is it true to that great of an extent of it being worthless ?
Re: i/h .. how much will an exhaust help ? (RacerXintegra2k)
It is a system. It all works together. You need to consider your power goals in the long run, size your exhaust piping accordingly, and buy all your components so they work together.
Join and read the articles at http://www.team-integra.net/
Ben
Ben
Re: i/h .. how much will an exhaust help ? (mr_mbuna)
i'm on ti already i've read articles and am going to go with a 2.25 mandrel bent with itr stock exhaust i want low loise levels. but you know how like exhaust does .. 2whp or whatever and header does like 5whp .. will there be more if there both there togther instead of like 7whp .. will the pair do maybe 10whp ? somthing like that
the stock cat will be the big choker, get a random tech hi flow, theyre also 50 state legal and flow about 6786087 timesbetter than the stocker
exhaust definitely helps out. especially if you opt for the whole "package" muffler, larger piping, straight pipe, ect. and power increase also depends on what muffler you get too. but i definitely recommend an aftermarket exhaust setup.
Re: i/h .. how much will an exhaust help ? (b18C1_liLkyLe)
so muffler is important ? i figure the itr muffler would be good since itrs have 195hp and i wont have anywere close to that so flow shouldt be a problem with that + it looks stock and is low in noise lvl compared to afermarket. let me get your input on that
The problem with the ITR and similar A'PEXi World Sport exhaust is that they are NOT straight-through exhausts... they have a pipe into the muffler, some baffles, and a different pipe out of the muffler. A straight through like the Comptech will give better gains, and with a Quiet Tip Insert, the Comptech is a power adder with straight-through design and Stock Power Levels.
Ben
i know what u mean about not assigning hp #'s i was just trying to see if the package would hit up more overal than just piece by piece. so the itr muffler is a no no ? str8 through design is the way to go... but i hate the look of those canister type things
Ben
yea i saw surferx's dyno real nice will it be a huge difference between an itr muffler or a str8 through in power.. noise thats basically i think what i want to know ... oh yea also .. a mufflers shops custom bent cat back ... compared to a already made one whats better ? sorry for the n00b questions but you guys are being real quick to take care of all my exhaust questions tonight
ITR exhaust isn't a no-no... It is a better exhaust than LS/GSR have... and it is only $200 used so if you're on a budget go for that. I, however, decided the Comptech unit was worth the money. On here (honda-tech), Dr.Rab01GSR is selling his Comptech 4-2-1 header in perfect condition and I am sure you can find a used Comptech catback if you want it.
The Comptech uses an oval muffler, not a round coffee can.
Comptech Exhaust:
Ben
Comptech Exhaust:
Ben
the muffler is definitely important, air flow definitely differs from muffler to muffler. currently my exhaust set up on my 98 gs-r is... 2.25 piping, no cat, and an axel back A'pexi N1 muffler with mandrel bent piping. i noticed a nice increase in top end power and a definite change in sound, which contrary to some opinions, i love. the N1 owns!!! hehe. an itR set up would for sure be an improvement though if that.s the route you're going to take.
i like the way that comtech muffler looks .. how much for that .. and its 200 beans for just an itr muffler or full itr exhaust ??? good god thats mad loot
The full ITR exhaust, from the cat back and maybe including the ITR cat, hovers around $200 used online. Think that's expensive...
The Comptech catback exhaust is now around $650 new. http://www.diabloautosports.com/ for a new one. Used, they run around $400 in good condition. The Comptech header is $369 new, for the MIG version. A catalytic converter will run about $160 or so.
Ben
i'm gonna get teh itr catback new .. unless i can find it used in great shape .. but the oem itr catback will bolt up right up to my 2k ls ? or do i have to modify it a little . ragejed told me a new flange would have to be welded on
I have a Comptech Axle back for sale right now....it bolts right up to the ITR
B-pipe. I'm selling it for 160+shipping!!
Re: i/h .. how much will an exhaust help ? (Mikes01GSR)
You could do the ITR catback... new its probably gonna be real pricey and not worth it. Or you could buy Mike's Comptech axleback (usually what, 350 new?) to your local muffler shop and have them install it on your car with custom 2.25" mandrel bent piping. Whatever you wanna do.
Ben
Ben
alfaaay
08-08-2003 12:46 AM
CW-ITR-329
12-29-2001 04:58 PM
