Electrical/Fan wiring
Okay so when I bought my DA, the fan was ghetto rigged. By that I mean that there is a foreign bright blue wire that someone ran from the negative terminal all the way around the front to the left side of the vehicle, in to the driver's side door, down under into the fuse box near my left leg.
So basically I want to fix this and i need a map or diagram of the electrical wiring involved in this.
I looked around on here and I couldn't find anything, does anyone have any links or information?
Thanks guys
Thanks guys
Re: Electrical/Fan wiring
There is one in the Haynes manual, I would imagine that you could download a pdf from somewhere if you don't have the twenty bucks for one, but I will see what I can do I have one but my scanner is not working. If the relay is still intact you could just rewire it to the relay, should be easy, and if it doesn't work replace the coolant temperature sensor. It probably went bad in the first place and they had no Idea what to do
So yeah i see those manuels, the haynes and chilton, and i've seen them before. IS there ANY, like, shop repair manual for JUST a gen 2 integra? or just integra and year specific? or are those acura integra/legend combined ones the best i could get?
I realize they probably have everything I need, but I'm just curious.
actually no it goes from the neg terminal to the a fuse inside and i guess from there to the fan, i honestly have no idea how it works yet. hence needing a diagram
Jays91DXhatch
05-11-2004 08:06 AM
