ls cable to hydrolic
Old Sep 12, 2004 | 07:49 PM
the DA in HONDA's Avatar
Default ls cable to hydrolic
i was wondering how hard it would be to swap a 90 ls teg tranny for a new hydro tranny and i have searched and i can't find a swap kit like made by hasport or anywhere else. thanks
Old Sep 12, 2004 | 08:23 PM
steven975's Avatar
Default Re: ls cable to hydrolic (the DA in HONDA)
i think there are hyrdro to cable conversions, but not vice versa. it's quite a bit of work and i have not heard of it being done.
you should get a del sol b16 cable tranny. they are cheap.
Old Sep 12, 2004 | 08:28 PM
Default Re: ls cable to hydrolic (steven975)
i would get a b16 tranny but its gonna be my daily driver and i don't want to be at high rpms at all times
Old Sep 13, 2004 | 08:49 PM
steven975's Avatar
i think you can use a pre-94 LS tranny. I don't know if you can add the hydro tranny without a lot of work. I've been here a while and have never heard of it being done. lots think, but no one does.
Old Sep 13, 2004 | 08:57 PM
Slain's Avatar
a guy on http://www.g2ic.com did a write up on how to do a cable to hydro conversion.
Old Sep 13, 2004 | 09:02 PM
jaydeemmmm's Avatar
Cable to hydro convertion is alot of work. From HondaHookUp.com 92TypeR said, " Don't waste your time and money. I can do 3 engine swaps before I finsh with a cable to hydro convertion."
Old Sep 13, 2004 | 09:35 PM
HARI.'s Avatar
Default Re: (jaydeemmmm)
i did it using the hasport cable to hydro. haven't had a problem with it yet
Old Sep 13, 2004 | 10:20 PM
MR Dan's Avatar
66.116.69.217
Default Re: (deeaye9)
Hows the clutch pedal pressure compared to stock???
Old Sep 13, 2004 | 10:22 PM
HARI.'s Avatar
Default Re: (DP24)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DP24 &raquo;</TD></TR><TR><TD CLASS="quote">Hows the clutch pedal pressure compared to stock???</TD></TR></TABLE>
it's still the same. still have the cable feeling.
Old Sep 13, 2004 | 10:25 PM
purplegsr's Avatar
Both Place Racing and Hasport make the kits, here is the writeup from g2ic.com
http://www.g2ic.com/forums/showthread.php?t=90904
Old Sep 14, 2004 | 08:56 AM
Default Re: (purplegsr)
thanks a lot the only reason why i want to go with a hydro clutch is because its getting hard to find a tranny with low miles if its cable and not a b16 tranny. thanks a lot for the help
Old Sep 14, 2004 | 09:07 AM
MR-MUGEN's Avatar
Default Re: (the DA in HONDA)
also looking at this - not because of the tranny , but because the cable tranny gets hot and you start losing your tranny and a hydro tranny is always flowing and always about the same temp.
Old Sep 14, 2004 | 09:33 AM
psychotic_z's Avatar
Default Re: (jdm92daintegra)
BS BS BS... Go to that g2ic.com write-up. Converting from a cable clutch system to hydro clutch system doesn't seem all that difficult (I say that since I haven't done it myself, I'll let the people who actually did it speak).
There's two ways you can run a hydro tranny though -
1. Do the full hydro conversion. That involves buying a 94+ clutch pedal, clutch master cylinder, and misc. lines. Drill a hole in your firewall and mount the master cylinder. Switch out clutch pedals. Run lines to the slave cylinder. Bleed and you're in business (in a nutshell). Doing it this way provides the hydro clutch feel as well.
2. Do the Hasport or Place Racing cable-&gt;hydro conversion. You're still essentially running a cable setup, therefore the cable clutch feel will still be there. However, the process is easier and less intensive.
And guys, come on. Go to g2ic.com and you'll see a ton of people who've done this swap. Nobody does it on here because the majority of the Integras on here are 3rd generation (allllll hydraulic clutch systems).
x92preludesix
Oct 24, 2021 05:40 AM
90ED6LSV
Nov 1, 2011 01:08 PM
DelSols-plural
Sep 21, 2011 07:25 AM
LSpimpTEC
Jun 15, 2004 07:38 PM
Dumped DB2
Apr 11, 2004 11:46 PM
