how to tell what year b18a
Old 01-07-2004, 06:22 AM
jdmcx's Avatar
Default how to tell what year b18a
is there a way you can tell what year b18a you got reason i am asking is because i need to order a rear main seal and i need the year thanks
Old 01-07-2004, 08:23 AM
Devlins 91LS's Avatar
Default Re: how to tell what year b18a (jdmcx)
i'm pretty damn sure they're the same from 90-93
But if you really need to know, on the front of the block, towards the distributor there should be four little dial looking things...
For an example it would look like
(9|0) or (9|2) I believe its the....crap...i don't remember which one it is, there should be four. Its gonna be the one that has a number between 90 and 93 lol
Old 01-07-2004, 10:03 AM
sPaRk'iT's Avatar
Default Re: how to tell what year b18a (Devlins 91LS)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Devlins 91LS &raquo;</TD></TR><TR><TD CLASS="quote">i'm pretty damn sure they're the same from 90-93
(9|0) or (9|2) I believe its the....crap...i don't remember which one it is, there should be four. Its gonna be the one that has a number between 90 and 93 lol</TD></TR></TABLE>
b18a are 90-93, correct.
Old 01-07-2004, 12:31 PM
Default Re: how to tell what year b18a (sPaRk'iT)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sPaRk'iT &raquo;</TD></TR><TR><TD CLASS="quote">
b18a are 90-93, correct.</TD></TR></TABLE>
Well duh. But he was wondering what year b18a he had.
There were a few slight changes in 92, which is why i told him how to find when his engine was manufactured. However, i don't think the part that he's looking for had been changed. As stated previously.
Old 01-07-2004, 02:46 PM
xteg95's Avatar
if the VIN is still on the block it says the year.
Old 01-07-2004, 02:50 PM
the buddha's Avatar
what the first guy said its the one near the
distrubutor
Old 01-08-2004, 08:25 PM
TyPe_R_GuY's Avatar
if you look on the front of your head, right above the header/exhaust manifold, you'll see some little cirles with numbers in them (like mentioned before) the little circle to the VERY left, will have the year of the motor
Old 01-09-2004, 04:57 AM
jdmcx's Avatar
Default Re: (TyPe_R_GuY)
i only have a short block
Old 01-09-2004, 07:01 AM
JimBlake's Avatar
Default Re: (jdmcx)
Check the block serial #. The first digit is supposed to indicate the year, based on when the engine was available.
For example the block in my '95 GS-R has a serial # of B18C1 - 2nnnnnn which means it's the 2nd year that engine was available. But I don't know when the B18A was first available...
Old 01-12-2004, 06:09 AM
jdmcx's Avatar
Default Re: (JimBlake)
thanks
Too-R3ckl3ss
01-01-2013 04:01 PM
duckmanEG
11
12-17-2010 12:57 PM
96hondacoupe
12-24-2007 03:17 PM
darkstarmeyers
08-28-2006 11:41 PM
kyorishin
04-24-2006 10:26 PM
Quick Reply: how to tell what year b18a
