How hard is it to replace a clutch?
Old Jan 4, 2007 | 08:54 AM
super china china's Avatar
Default How hard is it to replace a clutch?
Im buying a 94 Ls and the Stage 2 was put in wrong and it grinds sometimes, how hard is it to change out?
Old Jan 4, 2007 | 01:24 PM
Schister66's Avatar
Man U FTW
its not something i would recommend you try unless you have worked on cars before. I dont know how much experience you have, but i have done a lot of work on Hondas and other cars....i did my clutch alone and it wasn't difficult, just time consuming. It would be a ton easier if you had help.
Old Jan 4, 2007 | 01:33 PM
DBAl's Avatar
Default Re: (Schister66)
http://www.c-speedracing.com/h...h.php
Old Jan 4, 2007 | 02:03 PM
PrinceAli132's Avatar
Default Re: (DBAl)
Its not to bad. Get a helms if you don't have one, and just follow the steps and make sure to retorque everything.
http://www.team-integra.net/se...D=957
Ali
Old Jan 4, 2007 | 02:07 PM
Boots's Avatar
Default Re: (PrinceAli132)
if you dont know how to do it...its a perfect way to learn...it does suck doing it on your back in your garage though
akandok's Avatar
make sure u use a clutch alignment tool......
Old Jan 4, 2007 | 02:46 PM
DB1_559's Avatar
Default Re: How hard is it to replace a clutch? (super china china)
its pretty easy just time consuming
Old Jan 4, 2007 | 03:25 PM
And instead of removing the shift linkage from the tranny just drop the tranny with the shift linkage and disconnect it from the shifter.
The pin to remove is commonly known as "bitch pin" for obvious reasons.
Ali
Old Jan 4, 2007 | 03:59 PM
mike5809's Avatar
Default Re: How hard is it to replace a clutch? (PrinceAli132)
the first major repair i did back when i was young was replaced a clutch in my old teg. i didnt have enough for a shop to do it so i baught a shop manuel and did it myself.
just have to have right tools, dont get frustrated, and it is time consuming the first time.
Old Jan 4, 2007 | 04:39 PM
Sam92Teg's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super china china &raquo;</TD></TR><TR><TD CLASS="quote">Im buying a 94 Ls and the Stage 2 was put in wrong and it grinds sometimes, how hard is it to change out?</TD></TR></TABLE>
Make sure it's a clutch problem and not a tranny problem, like low MT fluid, clutch master cylinder, clutch slave cylinder, improperly bled system, or even tranny syncros. Would suck to swap the clutch and still have the grind.
Old Jan 4, 2007 | 04:59 PM
Default Re: How hard is it to replace a clutch? (Sam92Teg)
no im pretty sure its the clutch because the guy said that it never grinded till he put that new clutch in so hes sure thats what it is.
Old Jan 4, 2007 | 05:04 PM
Schister66's Avatar
Man U FTW
well if it never ground gears and then he replaced the clutch and it did, i would wager a guess that HE screwed something up. Check the fluid, the check if the axles are in all the way, then check to see whether the clutch fluid was bled after install (provided its a hydro)
Old Jan 4, 2007 | 11:40 PM
vladd's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by super china china &raquo;</TD></TR><TR><TD CLASS="quote">no im pretty sure its the clutch because the guy said that it never grinded till he put that new clutch in so hes sure thats what it is.</TD></TR></TABLE>
are you pressing the clutch all the way to the floor before shifting? with my exedy stage 2 i noticed that if the pedal isn't on the floor when shifting the gears will grind a bit. i don't think there really is a way to 'install a clutch wrong.' it'll only go on one way.
Old Jan 5, 2007 | 12:01 PM
Default Re: How hard is it to replace a clutch? (civicdxtyper)
no i havent driven it yet, i get it the end of next week. (hopefully) but right now im just going on what he says
egstockboosted
Jan 15, 2008 03:28 PM
tenny91
Sep 1, 2007 03:25 AM
VtecAdvantage
Apr 23, 2006 11:02 AM
Lookincrazy
Aug 10, 2002 03:26 AM
onesojourner
11
Jun 7, 2002 09:17 PM
