How hard is it to install headers?
Old Mar 6, 2002 | 02:59 PM
mickey513's Avatar
Default How hard is it to install headers?
I am getting new a new header install for my gsr. I was wondering how hard will this be? I heard it was a pain in the *** if espececially if you had AC. Any tips or suggestions?
Old Mar 6, 2002 | 03:05 PM
Cramerox's Avatar
Default Re: How hard is it to install headers? (mickey513)
It takes some squezing in.....main thing is to have the right tools. your going to need a bar that can check the torqe of each bolt thats very important so u dont get any exhst leaks.
Old Mar 6, 2002 | 03:08 PM
GSRaCeRbOI's Avatar
not hard at all just takes time.. make sure you have all the gaskets beforehand and that you dont snap any of the bolts..
Old Mar 6, 2002 | 03:31 PM
keck's Avatar
And remember to get some Loc-tite to keep the old bolts from vibrating out unless you buy new ones ($2 each). The torque specs are 23ft-lbs for the bolts and 31 ft-lbs for the black nuts that go on the bolts from the engine block. I just did it 3 times in the last two weeks. Its easy and takes about 1.5 - 2 hours if you know what you are doing.
Old Mar 6, 2002 | 03:33 PM
Scary1109's Avatar
Default Re: How hard is it to install headers? (keck)
it's pretty easy, just get your car up on stands and put the headers in from the bottom up. that's what i did last summer on my gsr, it took maybe 1.5 hours.... but i am slow. good luck.
-Scott
Old Mar 6, 2002 | 04:09 PM
crazyteg's Avatar
its a real pain getting off the stock header if you don't have power tools. it took us about 2 hours. its not hard, you just have to remove the heat shield, unbolt everything, then bolt on the new header. take your time and have fun.
Old Mar 7, 2002 | 02:44 AM
5-SpeedFreak's Avatar
New User
Default Re: How hard is it to install headers? (nightcrawler808)
This is a fun mod. Just take your time. I do recommend being REALLY REALLY easy on those header bolts! I've heard of nightmares of people snapping 'em.
Torque them easy with a deep socket ratchet. Don't skin your knuckles like I did (battle scars)
Good Luck!
Old Mar 7, 2002 | 03:05 AM
alexboy's Avatar
Default Re: How hard is it to install headers? (5-SpeedFreak)
Not hard at all take your time with the boltsor you can have a problem with them breaking
Old Mar 7, 2002 | 05:29 AM
dlslvtch21's Avatar
Default Re: How hard is it to install headers? (alexboy)
I have a quick question, I'll be installing my Comptech 4-2-1 header saturday, and needed to know if the heat shield can be reinstalled for the aftermarket header or will it not fit??
Old Mar 7, 2002 | 05:33 AM
ebelp's Avatar
Default Re: How hard is it to install headers? (dlslvtch21)
Why would you want to put a heat shield over a beautiful piece of performance art?! The only reason the heatshield is there, is so dumbasses won't grab the headers when the engine is piping hot. It serves no other purpose.
Old Mar 7, 2002 | 05:59 AM
Scary1109's Avatar
heat sheilds aren't very useful on headers, it would be hard to attach them and those are so pretty so don't cover them up.
-Scott
Old Mar 7, 2002 | 06:42 AM
dlslvtch21's Avatar
Default Re: How hard is it to install headers? (ebelp)
The reason being is that, I bought the header used, and I can't get it exactly polished how I like it....
Old Mar 7, 2002 | 07:36 AM
SpeedMonkeyRacing's Avatar
how hard is it to get *****? it's easy for some people and hard for the others you never know till you try it right?
Jeff-
Old Mar 7, 2002 | 07:40 AM
96IntegraLS4DR's Avatar
2-piece header is easier to install.
The more ground clearance you have, the easier it gets.
Old Mar 7, 2002 | 07:46 AM
Jesse H's Avatar
Heat shields are helpful in keeping the underhood temps down. If if I could use one with my DC Sports I would.
H23_Lude4_2_0
Oct 21, 2010 11:28 AM
doubleecho
Jul 20, 2007 06:09 AM
Manolo
Suspension & Brakes
May 12, 2006 11:36 AM
miguelsanroman
Aug 9, 2003 02:59 AM
ebelp
Mar 1, 2002 05:16 AM
