How do you change the alternator belt on a b18b?
Can somebody please list all the steps needed and any extra tips, etc. to changing the alternator belt on a '95 LS motor.
Re: How do you change the alternator belt on a b18b? (1.8 HB)
Please do yourself a favor and get a helms... I just did this on my car it takes a while especially if you don't have amazing tools (I don't).
1. You have to take off the power steering belt first, pretty straighforward, loosen the adjuster screw and take the mounting bolts off to move it around and make life easier.
2. Remove A/C belt... unfortunatly to do so you have to take out an engine bolt to get the belt around it... its a pain in the ***.
3. Remove alternator belt... be carefull not to strip the screws
It took me and a friend a good couple of hours of leisure removal and replacement of all my betls... its not really hard but time consuming especially in 90degree heat and 100% humidity in jersey.
Re: How do you change the alternator belt on a b18b? (shadowdawn)
I don't have A/C or P/S so i guess it should be much easier? What's the torque spec on that?
519[H]Si
05-25-2004 09:25 PM
