hondata or uberdata?
Old Jul 8, 2005 | 10:10 AM
fatal lightning's Avatar
Default hondata or uberdata?
which would you prefer to use for your 1996 gsr
hondata or uberdata? and why?
Old Jul 9, 2005 | 12:22 PM
yee SERIOUS's Avatar
to do what? everyone likes uber cause it's like "free"
Old Jul 9, 2005 | 02:48 PM
mtber's Avatar
Default Re: (LiTtOGPiMp)
Use what your local tuner likes to use
Old Jul 11, 2005 | 05:01 PM
nicklk's Avatar
Default Re: (mtber)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by mtber &raquo;</TD></TR><TR><TD CLASS="quote">Use what your local tuner likes to use </TD></TR></TABLE>
Buy a wideband, chip burner, and read up and tune yourself....use the money you saved and buy more **** to make your car faster!
Old Jul 11, 2005 | 05:35 PM
Yambor's Avatar
Default Re: (nicklk)
learn from nick. Good post, simple, yet explains it all..
Are you from TI Nick, or maybe you have the same user name as one on there?
Well that was just about the dumbest thing ive ever posted on here.. its right in your sig..
Old Jul 11, 2005 | 06:58 PM
adaml2nv's Avatar
Default Re: hondata or uberdata? (fatal lightning)
umm you can't use that on a 96 unless your converting to obd1. then i personaly like hondata
Old Jul 11, 2005 | 07:03 PM
nicklk's Avatar
You cant use Hondata either unless you convert to OBD1????
Old Jul 11, 2005 | 09:24 PM
The Droogan Leader's Avatar
Now with ultra-violence!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by nicklk &raquo;</TD></TR><TR><TD CLASS="quote">You cant use Hondata either unless you convert to OBD1????</TD></TR></TABLE>
Is this true? I think I've heard that only Greddy's (it might have been AEM's) that only worked on OBD2...
Old Jul 11, 2005 | 09:32 PM
nicklk's Avatar
It is true........
Old Jul 11, 2005 | 09:46 PM
fastrunner's Avatar
OBD1 owns you all
Old Jul 11, 2005 | 09:51 PM
Rod.'s Avatar
Default Re: (fastrunner)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by fastrunner &raquo;</TD></TR><TR><TD CLASS="quote">OBD1 owns you all</TD></TR></TABLE>
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by adaml2nv &raquo;</TD></TR><TR><TD CLASS="quote">umm you can't use that on a 96 unless your converting to obd1. then i personaly like hondata </TD></TR></TABLE>
i agree
Old Jul 12, 2005 | 04:02 PM
PandaBear's Avatar
Default Re: (Rod.)
If you want your tuning done quick and your local tuner like Hondata, use it. It is a superior system over uber as the feature is more developed, and there is a company behind to back it up.
If you like to experiment and learn the nuts and bolt, uber will be better as you have more things that you can do and you can burn your own chip, tune on your own, etc, plus it is free.
Both are good.
Old Jul 12, 2005 | 07:42 PM
honda1982's Avatar
Hondata all the way. Unless you are strap on money than uberdata is fine. both work well but Hondata has been proven on many Dragster time and time.
Old Jul 12, 2005 | 07:55 PM
Cliffjumper2's Avatar
true...just go to hondatas website and see for yourself
Old Jul 12, 2005 | 08:06 PM
FastSS's Avatar
Default Re: (Cliffjumper2)
You have to convert to OBD-1 regardless of whether you use Hondata or Uberdata. You also use the same equivalent tools to burn chips and real-time edit with both systems, so the cost difference is in buying either a S100 or S200 and the ROMeditor software license.
Personally, I hate working with Uberdata. Half of the parameters don't effect any changes like they're supposed to and the datalogger sucks. I feel like I'm always working half blind when I use Uberdata.
The Hondata datalogger is really comprehensive and integrates over to the ROMeditor software with map/lambda tracing, and real-time readouts for TPS/MAP/RPM/lambda.
If you can't afford HOndata, then at least consider using Crome.
Old Jul 13, 2005 | 09:19 PM
Default Re: (honda1982)
thanks again guys
i dont really know a lot about cars
i just drive it
Old Jul 13, 2005 | 09:36 PM
Dee's Avatar
Dee
Default Re: (fatal lightning)
I have a Hondata S200B with datalogging and 2 step rev limiter up for grabs. Send me a PM if you are interested.
Old Jul 13, 2005 | 10:05 PM
SynTeg's Avatar
If you have money go with the Hondata. If you have no money and you are a Do It Yourself kind of person get the Uberdata and wideband and tune it yourself.
Old Jul 13, 2005 | 10:32 PM
93tegy's Avatar
I would get crome over both but thats just me.
Old Jul 14, 2005 | 01:56 AM
Dee's Avatar
Dee
Default Re: (93tegy)
S300 = no burning chips
crome = still burning chips
Old Jul 14, 2005 | 02:16 AM
Sifu's Avatar
Default Re: (SynTeg)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SynTeg &raquo;</TD></TR><TR><TD CLASS="quote">If you have money go with the Hondata. If you have no money and you are a Do It Yourself kind of person get the Uberdata and wideband and tune it yourself.</TD></TR></TABLE>
Depends on what type of person you are, the amount of money you have and the access to local tuners.
jjspec
Feb 6, 2008 02:03 PM
ABK
Nov 11, 2007 08:20 PM
wrinkles
Oct 10, 2006 09:20 PM
Suprdave
Jul 28, 2005 12:28 AM
JDMCRX
Aug 26, 2003 07:14 AM
