hondata help
Old Dec 24, 2003 | 07:57 PM
prestonpark's Avatar
Default hondata help
i just installed my hondata with 3 step
i just set up my rev limiter now when i try to set it up again the engine light keeps on flashing i need help but when i touch the brakes it stop i need help
Old Dec 24, 2003 | 11:22 PM
Default Re: hondata help (civic2003)
does NY ONE KNOW WASSUP LET ME KNOW
Old Dec 25, 2003 | 08:36 AM
m R g S r's Avatar
What engine light is flashing, check engine? Sounds like wiring maybe. What ECU are you using?
Old Dec 25, 2003 | 10:44 AM
Default Re: hondata help (m R g S r)
my check engine light is flashing whne im on the setting mode when i press the button on nuettral
whne i press the button once it keeps on flashing until i hit the brakes
Old Dec 25, 2003 | 11:13 AM
tooky2's Avatar
its possible that the ecu could be flashing engine codes count the flashes and call a mechanic or hondata and see if the codes mean anything if they do then it may be pointing you in the direction of the problem
Old Dec 25, 2003 | 11:28 AM
Default Re: hondata help (tooky2)
it only flashes whne i press the button ones then whne i hit the brakes it stops
i can set my luanch control but no the rev limit
Old Dec 25, 2003 | 12:54 PM
any one with hondta a experience
Old Dec 25, 2003 | 06:12 PM
man i cant rev to 6 i need some help and it not on limp mode
GABOCRX
Engine Management and Tuning
Jun 7, 2015 09:41 PM
prestonpark
Dec 26, 2003 10:41 AM
turboex
Jun 11, 2002 03:01 AM
