Which side of gasket to apply hondabond...
Old Nov 17, 2004 | 03:10 PM
8point6's Avatar
Default Which side of gasket to apply hondabond...
I've searched and can't find the answer I'm looking for. I'm going to install a new valve cover and gasket. I am wondering if I'm supposed to apply hondabond on the head side, the cover side, or both sides of the gasket.
Modified by 8point6 at 4:33 PM 11/17/2004
Old Nov 17, 2004 | 03:21 PM
Boofster's Avatar
Default Re: Which side of gasket to apply hondabond... (8point6)
just bottom
APEX CRX's Avatar
in my Helms for my B-series it shows as in between the gasket and valve cover. especially in the corners of the cams curves
Old Nov 17, 2004 | 03:32 PM
drdisco69's Avatar
Default Re: Which side of gasket to apply hondabond... (APEX CRX)
Don't apply it all around, just in the corners where it goes over the cam caps. The rest will just squeeze out and make a mess.
8point6's Avatar
Just bottom?? Of what, the vc or the gasket?
Old Nov 17, 2004 | 03:34 PM
drdisco69's Avatar
The gasket.
Old Nov 17, 2004 | 03:35 PM
8point6's Avatar
Default Re: Which side of gasket to apply hondabond... (drdisco69)
I know that, my question is concerning which SIDE of the gasket to put it on.
Thanks though.
Old Nov 17, 2004 | 03:37 PM
8point6's Avatar
So I should put the hondabond on the head side? This is contradicting the other guys suggestion.
Old Nov 17, 2004 | 03:45 PM
drdisco69's Avatar
1. Turn the valve cover upside down.
2. Install the valve cover gasket.
3. Apply a small dab of Hondabond to the corners of the valve cover gasket where the valve cover goes over the cam caps. You should have 4 spots on a single cam, 8 on a dual cam.
4. Install valve cover and tighten bolts.
5. Perform burnout.
Old Nov 17, 2004 | 04:39 PM
8point6's Avatar
thanks
Old Nov 17, 2004 | 08:20 PM
Bandit74's Avatar
What's burnout?
Old Nov 17, 2004 | 08:23 PM
drdisco69's Avatar
Default Re: (Bandit74)
Old Nov 17, 2004 | 10:07 PM
B18OnTop's Avatar
Default Re: (drdisco69)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by drdisco69 &raquo;</TD></TR><TR><TD CLASS="quote"></TD></TR></TABLE>
i like that
Old Nov 18, 2004 | 05:31 AM
drdisco69's Avatar
Default Re: (B18OnTop)
I used to have the video for it. The guy in the silver one with black stripes isn't burning his tires, he's burning his clutch.
cyclonedr
Sep 2, 2019 01:09 PM
foowitdaredek
Mar 6, 2015 01:44 PM
b20acura
Mar 5, 2007 03:22 PM
dohcteg
Dec 23, 2006 12:03 PM
