High Idle!!!!
Old Dec 4, 2004 | 07:46 PM
Steezn4NOReason's Avatar
Default car is idleing really high....
do tegs have a manual idle adjust or is it a senser? how can i adjust the idle....
Modified by Steezn4NOReason at 9:01 PM 12/4/2004
Old Dec 4, 2004 | 08:17 PM
boosted k20's Avatar
Default Re: car is idleing really high.... (Steezn4NOReason)
look on the throttle body. u will see a recessed flat head screw. turn that screw clockwise to lower ur idle speed
Old Dec 4, 2004 | 08:56 PM
IVI's Avatar
IVI
Default Re: car is idleing really high.... (boosted k20)
look at the gold colored spot on top of the throttle body with the slit in it.
use a flat head screw driver and you can adjust your idle from there.
there may be some silicon or something plugged in there to keep it from moving just remove it and then you can see the bolt
Old Dec 4, 2004 | 09:00 PM
Default Re: car is idleing really high.... (IVI)
u cant really see the screw from that picture
Old Dec 4, 2004 | 09:02 PM
IVI's Avatar
IVI
its in the 12 o clock position.
you cant really see it but i was showing it for a general idea on a pic i had already posted.
Crxdriver1989
Dec 19, 2017 01:28 AM
BDogggUT34
Jan 18, 2005 04:05 PM
Mr. JDM-GSR
Oct 4, 2004 06:16 PM
fe519
Nov 21, 2002 05:58 PM
