Question - LS/VTEC Pistons
Old Jan 31, 2008 | 03:11 PM
ys1civicsi's Avatar
Default QUESTION ABOUT LS/VTEC TURBO PISTONS HELP!!!
I had a prior post but it just disappeared so I am reposting. I have decided to go turbo instead of NA so now I need to know what pistons to use. I know to use forged internals So do I buy forged LS rods with LS pistons or forged LS rods with VTEC pistons? I have searched and have been told both I was told by a member here on Honda tech to use the LS rods and LS pistons and then I was also told to use LS rods with VTEC pistons from a search I had done on Google. Looking to run 10-12 psi on stock sleeves at 9.0:1 comp. I am sorry to be repetitive but I am lost on what to use. Let me know what you are running thanks again and foe dealing with a pain in the ***.
Old Jan 31, 2008 | 03:45 PM
HondaCivicSiR1's Avatar
Default Re: QUESTION ABOUT LS/VTEC TURBO PISTONS HELP!!! (ys1civicsi)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by ys1civicsi &raquo;</TD></TR><TR><TD CLASS="quote">I had a prior post but it just disappeared so I am reposting. I have decided to go turbo instead of NA so now I need to know what pistons to use. I know to use forged internals So do I buy forged LS rods with LS pistons or forged LS rods with VTEC pistons? I have searched and have been told both I was told by a member here on Honda tech to use the LS rods and LS pistons and then I was also told to use LS rods with VTEC pistons from a search I had done on Google. Looking to run 10-12 psi on stock sleeves at 9.0:1 comp. I am sorry to be repetitive but I am lost on what to use. Let me know what you are running thanks again and foe dealing with a pain in the ***. </TD></TR></TABLE>what is you hp goal?you can really go off i want my car to run 10-12 psi.as for rods and pistons cp,wiseco etc.pistons 9.1-10-1 depending on your hp goal eagle,crower rods for a ls motor.
Old Jan 31, 2008 | 05:06 PM
Death_to_Thieves's Avatar
For the 3rd time......
Aftermarket pistons and rods of your choice for an LS if you are using an LS block and crank.
Old Jan 31, 2008 | 05:43 PM
ys1civicsi's Avatar
Default Re: QUESTION ABOUT LS/VTEC TURBO PISTONS HELP!!! (JAYSEM Society)
Thanks and again the post got deleted so I wasn't able to read all of it JAYSEM I am sorry for being a pain in the *** but thanks again.
Old Jan 31, 2008 | 05:48 PM
ys1civicsi's Avatar
Does the compression ratio of the pistons in general matter because i know when you are looking at pistons they say 9.0:1 compression ratio but this is for the motor they are intended to go in like an LS per say you put a 9.0:1 LS pistons in an LS/vtec what would I expect due to the vtec head giving more compression.
Old Feb 1, 2008 | 03:58 AM
ys1civicsi's Avatar
bump anyone
Old Feb 1, 2008 | 08:08 AM
blackeg's Avatar
an lsvtec setup will raise your compression around .5-1.0 compression points over an ls motor depending on gsr or b16 head and how much mill/deck you do during rebuild.
i used to use the wiseco 81.5 mm 9:1 compression
Old Feb 4, 2008 | 06:44 AM
tony413's Avatar
GSR pistons / ls rods
ls pistons have a different size valve relief.
also 9:1-10:1 is fine for CR
Jdmsolutions
10
Feb 25, 2008 08:30 PM
spoonzdelsol
12
Aug 7, 2005 08:13 PM
projectTeG
Nov 9, 2003 11:32 AM
OEMJDM
Jun 30, 2002 01:01 PM
