HELP WANTED > Suspension (SPRINGS/STRUTS)
![Default](https://honda-tech.com/forums/images/icons/icon1.gif)
Hello! So I tried to set the integra (2000 gsr if it matters) with a strut/spring (h&r race and kyb gr-2) combo this weekend and ran into a bit of a road block, i figure someone on here can steer me in the right direction. so my problem is as follows: we had the fronts set up perfectly and in place and when we went to lower tthe car back down, the piston (center strut arm) just extended past the top hat. I dont want to take apart my stock suspension, so i picked so second hand tophats up, but I know I am missing parts, the kybs just came with the top nut and 2 weird hallowed out bolts, look kinda like a spacer. Not sure why I just got two of those but yea. So I pretty sure there needs to be a bump stop or a something to lock onto the strut arm inside the spring to stop it from traveling up. Let me know any insight you may have, by the way I have done some searching and have came up pretty empty, even checked the FAQ's thanks!
![](http://acuraautomotiveparts.org/acura/jsp/mws/catimgs/13st70_b28.gif)
There are two rubber halves (#7), one on the top of the top hat and one on the bottom they get pushed in, and the metal spacer (#14) you have goes in the middle. There is then rubber spacer that sits in between the spring and the top hat (#11). Finally a bumpstop on the shock. Don't forget the washer on top also before you put the nut on. You need to either take apart your stock shocks to get these parts or order them from Acura.
Yeah ive got most of that, at least top hat assembly, Im gonna need 10,11, and 12 Hopefully advance auto parts stocks that stuff but I doubt it, thanks for the input I kinda already had a idea thats what i need
#16 is the bump stop which you'll need,although they're a little pricey new from Honda (I think like $15 a side or something). Don't worry about the dust cover (#12) though. It's a metal tube that won't work on after market shocks. If you want a dust cover, order some P/S rack boots and use those, otherwise just don't worry about it. The guy who had my car before me installed his after market shocks w/ those metals ones and it REALLY messed things up. Bent a coilover permanently and did some other damage.
Wouldn't get your hopes up on Autozone having that stuff...You'll need to get it from Acura. Good luck man!
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by purplepassiongsr »</TD></TR><TR><TD CLASS="quote">no i need 15 washer and 16 bushing thing</TD></TR></TABLE>
There lies your problem. Don't half *** on such important components such as your suspension. In this case you're lucky you weren't able to drive away with it installed.
I have the OEM #15's available. PM me if you want them.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by VTEC_PRODUCTION »</TD></TR><TR><TD CLASS="quote">haha i did that once before...when i was 16 and dumb!</TD></TR></TABLE>
well thanks guys, like i said i knew something was up, im going to buddies to get set up, he has tons of stock suspension setups laying around so it will be free or 5 bucks total at the most. and vtec production thanks for all you help, jackass
reeder321
11-26-2008 06:05 PM
EriK20
06-20-2003 02:42 PM
