help with tranny
Old Dec 4, 2004 | 10:25 PM
b18bme's Avatar
Default help with tranny
You see just the other day my car starting acting messed up. it felt hard to get it into second, third, and reverse. what could be my problem????
well I already have a new clutch and lightened flywheel, should I just got get the clutchchanged, install flywheel, tighten shift linkage, install short shifter, put new tranny fluid in, and see where i'm at after that???? if that doesn't cure it then maybe I should just bye a gsr tranny some help????
Old Dec 4, 2004 | 10:26 PM
LSvtec03's Avatar
Default Re: help with tranny (b18bme)
you have an ls? just get a gsr tranny anyway.
ls tranny is teh suxorz...
Old Dec 4, 2004 | 10:28 PM
b18bme's Avatar
Default Re: help with tranny (LSvtec03)
oh ya forgot to mention that yes its an ls. i really don't have the money right now but if it had to happen I could come up with it
Old Dec 6, 2004 | 05:22 AM
b18bme's Avatar
anymore input please!!!!
Old Dec 6, 2004 | 05:29 AM
HONDA RR's Avatar
Did you try checking your transmission fluid to check to see if its low. If its not your trans fluid it might be your clutch. Does your transmisson grind?
Old Dec 6, 2004 | 06:04 AM
Dan GSR's Avatar
Default Re: help with tranny (MITSUBA)
does it go into gear fine with the engine off?
miles on the clutch?
Old Dec 6, 2004 | 07:09 AM
b18bme's Avatar
Default Re: help with tranny (Dan GSR)
my tranny does not grind at all, i will go check and see if it goes into gear with the engine off....but what would that accomplish???? I am not sure the miles on the clutch I just bought the car 2 weeks ago. It worked great now after about 2 weeks it is not going into 2nd, 3rd, and reverse very well.
more help please
edit* i just checked and when the engine is off it goes into all the gears the exact same so its just when the engine is on. WHAT DOES THAT MEAN!!!
Modified by b18bme at 4:36 PM 12/6/2004
Old Dec 6, 2004 | 09:44 AM
Dan GSR's Avatar
so it goes into all the gears fine with the car off?
mileage on transmission, mileage on clutch??
Old Dec 6, 2004 | 01:11 PM
b18bme's Avatar
well there is 70,000 on the car so i am guessing thats how many are on the tranny. I bought it from some professor up at the local university. so i don' t think it was driven to hard so the clutch most likely has the same amount.
Old Dec 6, 2004 | 01:50 PM
Dan GSR's Avatar
usually, when the car all of the sudden doesn't want to go into several gears
but will go into gear with the car off, it means the pressure plate is broken
change out the clutch and pressure plate
Old Dec 7, 2004 | 04:56 AM
b18bme's Avatar
sweet thanks man, i have a new stage 3 clutch from (Pro Clutch) and pressure plate, as well as an exedy lightened flywheel. my buddy is the manager of midas so i will just have him throw it in.
THANKS!!!!!!
blu3fan
Aug 13, 2010 09:22 PM
Kamikaze
Jul 12, 2007 12:52 PM
Kr4nG
Feb 26, 2007 08:13 AM
dynamo
Nov 19, 2005 04:06 PM
H.A.R.T b16a1crx
Aug 30, 2004 09:29 PM
